查看: 2633|回复: 4
[求助] 另设计USB,该如何仿真???
发表于 2012-10-31 12:46:39 | 显示全部楼层 |阅读模式
rt~
还是写testbench来仿真看时序?
还是说接电脑,用某些软件来进行仿真???如果是,用什么软件好?
发表于 2012-11-28 11:41:54 | 显示全部楼层
If you are designing a USB device, what you need is a USB host model to simulate the USB message behavior on the bus. You need to learn the command sets of the host model and edit it in your testbench. If your design is a full speed design, you can find host model from opencore website. For USB high speed design, there is no stable host model in free open source.
 楼主| 发表于 2012-11-28 11:49:37 | 显示全部楼层
回复 2# richyrichy
    thx~
 楼主| 发表于 2012-11-28 11:50:30 | 显示全部楼层
回复 2# richyrichy
    ps:opencores 上面的USB2.0的那个func请问下您用过没?
发表于 2013-1-15 21:49:48 | 显示全部楼层
回复 2# richyrichy
    同问,多谢!!!
GMT+8, 2025-12-25 14:50 , Processed in 0.025311 second(s), 6 queries , Gzip On, Redis On.
