楼主: luxiao6802
matlab R2012b 可用下载地址
发表于 2012-11-29 07:53:22 | 显示全部楼层
thanks a lot ...
发表于 2012-11-30 21:18:47 | 显示全部楼层
可惜不是最新破解文件
发表于 2012-12-2 14:53:07 | 显示全部楼层
How to install R2012B
How to install MATLAB R2012b:
1. Copy all files from DVD to your folder, for example, 'C:\MATLABSetup'
2. Replace  'C:\MATLABSetup\java\jar\install.jar' with 'install.jar' under 'Usual' or 'MPS' folder given in full crack)
   * Use 'Usual\install.jar' if you don't know about 'MATLAB Production Server'.
   * Use 'MPS\install.jar' if you REALLY need 'MATLAB Production Server'.
3. Install it by choosing 'Install without using the Internet' and by using serial of 23809-26556-08469-31324
4. Choose 'Custom install' to select components u want and uncheck 'MATLAB Distributed Computing Server 6.1' if you DON'T use MDCE.
5. Activate with file 'matlab2012b_std.dat' from this archive.
P.S. Execution results by 'ver' command have been written in 'ver.txt'.
发表于 2012-12-2 14:58:59 | 显示全部楼层
How to verify R2012B as a full crack
Execution results by 'ver' command have been written in 'ver.txt' as shown below.
(To verify full version for R2012B)
>> ver
MATLAB                                                Version 8.0        (R2012b)
Simulink                                              Version 8.0        (R2012b)
Aerospace Blockset                                    Version 3.10       (R2012b)
Aerospace Toolbox                                     Version 2.10       (R2012b)
Bioinformatics Toolbox                                Version 4.2        (R2012b)
Communications System Toolbox                         Version 5.3        (R2012b)
Computer Vision System Toolbox                        Version 5.1        (R2012b)
Control System Toolbox                                Version 9.4        (R2012b)
Curve Fitting Toolbox                                 Version 3.3        (R2012b)
DO Qualification Kit                                  Version 2.0        (R2012b)
DSP System Toolbox                                    Version 8.3        (R2012b)
Data Acquisition Toolbox                              Version 3.2        (R2012b)
Database Toolbox                                      Version 4.0        (R2012b)
Datafeed Toolbox                                      Version 4.4        (R2012b)
Econometrics Toolbox                                  Version 2.2        (R2012b)
Embedded Coder                                        Version 6.3        (R2012b)
Filter Design HDL Coder                               Version 2.9.2      (R2012b)
Financial Instruments Toolbox                         Version 1.0        (R2012b)
Financial Toolbox                                     Version 5.0        (R2012b)
Fixed-Point Toolbox                                   Version 3.6        (R2012b)
Fuzzy Logic Toolbox                                   Version 2.2.16     (R2012b)
Global Optimization Toolbox                           Version 3.2.2      (R2012b)
HDL Coder                                             Version 3.1        (R2012b)
HDL Verifier                                          Version 4.1        (R2012b)
IEC Certification Kit                                 Version 3.0        (R2012b)
Image Acquisition Toolbox                             Version 4.4        (R2012b)
Image Processing Toolbox                              Version 8.1        (R2012b)
Instrument Control Toolbox                            Version 3.2        (R2012b)
MATLAB Builder EX                                     Version 2.3        (R2012b)
MATLAB Builder JA                                     Version 2.2.5      (R2012b)
MATLAB Builder NE                                     Version 4.1.2      (R2012b)
MATLAB Coder                                          Version 2.3        (R2012b)
MATLAB Compiler                                       Version 4.18       (R2012b)
MATLAB Distributed Computing Server                   Version 6.1        (R2012b)
MATLAB Report Generator                               Version 3.13       (R2012b)
Mapping Toolbox                                       Version 3.6        (R2012b)
Model Predictive Control Toolbox                      Version 4.1.1      (R2012b)
Model-Based Calibration Toolbox                       Version 4.5        (R2012b)
Neural Network Toolbox                                Version 8.0        (R2012b)
OPC Toolbox                                           Version 3.1.2      (R2012b)
Optimization Toolbox                                  Version 6.2.1      (R2012b)
Parallel Computing Toolbox                            Version 6.1        (R2012b)
Partial Differential Equation Toolbox                 Version 1.1        (R2012b)
Phased Array System Toolbox                           Version 1.3        (R2012b)
RF Toolbox                                            Version 2.11       (R2012b)
Real-Time Windows Target                              Version 4.1        (R2012b)
Robust Control Toolbox                                Version 4.2        (R2012b)
Signal Processing Toolbox                             Version 6.18       (R2012b)
SimBiology                                            Version 4.2        (R2012b)
SimDriveline                                          Version 2.3        (R2012b)
SimElectronics                                        Version 2.2        (R2012b)
SimEvents                                             Version 4.2        (R2012b)
SimHydraulics                                         Version 1.11       (R2012b)
SimMechanics                                          Version 4.1        (R2012b)
SimPowerSystems                                       Version 5.7        (R2012b)
SimRF                                                 Version 3.3        (R2012b)
Simscape                                              Version 3.8        (R2012b)
Simulink 3D Animation                                 Version 6.2        (R2012b)
Simulink Code Inspector                               Version 1.2        (R2012b)
Simulink Coder                                        Version 8.3        (R2012b)
Simulink Control Design                               Version 3.6        (R2012b)
Simulink Design Optimization                          Version 2.2        (R2012b)
Simulink Design Verifier                              Version 2.3        (R2012b)
Simulink Fixed Point                                  Version 7.2        (R2012b)
Simulink PLC Coder                                    Version 1.4        (R2012b)
Simulink Report Generator                             Version 3.13       (R2012b)
Simulink Verification and Validation                  Version 3.4        (R2012b)
Spreadsheet Link EX                                   Version 3.1.6      (R2012b)
Stateflow                                             Version 8.0        (R2012b)
Statistics Toolbox                                    Version 8.1        (R2012b)
Symbolic Math Toolbox                                 Version 5.9        (R2012b)
System Identification Toolbox                         Version 8.1        (R2012b)
SystemTest                                            Version 2.6.4      (R2012b)
Vehicle Network Toolbox                               Version 1.7        (R2012b)
Wavelet Toolbox                                       Version 4.10       (R2012b)
xPC Target                                            Version 5.3        (R2012b)
xPC Target Embedded Option                            Version 5.3        (R2012b)
发表于 2012-12-4 11:03:04 | 显示全部楼层
谢谢楼主!
发表于 2013-1-18 10:14:12 | 显示全部楼层
鄙视这种发帖的
抄袭别人帖子里的东西做附件下载来赚积分
发表于 2013-1-20 02:12:15 | 显示全部楼层
想要2012b,立马就找到了,感谢楼主
发表于 2013-1-20 04:13:04 | 显示全部楼层
感谢楼主,用2012b
发表于 2013-1-20 12:30:45 | 显示全部楼层
多谢,链接可用|!
发表于 2013-1-30 01:52:40 | 显示全部楼层
Will this work with linux version?
GMT+8, 2025-12-24 20:54 , Processed in 0.166160 second(s), 3 queries , Gzip On, Redis On.
