查看: 26731|回复: 17
MATLAB2012b下载地址
发表于 2012-10-13 22:01:48 | 显示全部楼层 |阅读模式
MATLAB2012b下载地址以及全部78个工具包Crack
http://mac.pcbeta.com/redirect.php?tid=118783&goto=lastpost
工具包, java, 下载地址, folder, files
本体下载地址:http://matlab.tuc.gr/R2012b/
CRACK:[local]1[/local]
说明:
To install MATLAB R2012b make next steps:
1. Copy all files from DVD to folder on your hard drive, i.e 'C:\MATLABSetup'
2. Change file 'install.jar' in the folder 'C:\MATLABSetup\java\jar\install.jar' by 'install.jar' from this archive:
   * Select file 'Usual\install.jar' if you don't know what it is 'MATLAB Production Server'.
   * Select file 'MPS\install.jar' if you REALLY need 'MATLAB Production Server'.
3. Run 'setup.exe', choose 'Install without using the Internet', enter serial: 23809-26556-08469-31324
4. Choose 'Custom install' to select needed components. Uncheck 'MATLAB Distributed Computing Server 6.1' if you DON'T use MDCE.
5. Activate with file 'matlab2012b_std.dat' from this archive.
P.S. Result of execution of 'ver' are in 'ver.txt'.
MisterLamer
发表于 2012-10-15 07:32:37 | 显示全部楼层
这个下载地址比较好
发表于 2012-10-15 07:57:38 | 显示全部楼层
很好,謝謝分享!
发表于 2012-10-16 11:21:05 | 显示全部楼层
回复 1# hi_china59
    TBE还没有消息?呵呵。
 楼主| 发表于 2012-10-16 16:29:24 | 显示全部楼层
回复 4# weigaozu
enzyme_wy  原创 matlab 2012b 最全的破解
http://bbs.eetop.cn/viewthread.php?tid=355388&highlight=matlab%2B2012
发表于 2012-10-16 16:34:57 | 显示全部楼层
回复 1# hi_china59
oh my god! thanks a lot for that!
发表于 2012-10-18 12:00:14 | 显示全部楼层
之前已在别处找到这个破解
已装到Win 7上,完全装完将近10G,越来越夸张了
很多根本不可能用到的组件安装时可以去掉
不过楼主说是78个工具包
实际上好像是77个吧,包括Matlab和Simulink
和之前安装的7.0.1相比,界面是新了,不过暂时还没感觉到好还是不好
m文件内print输出emf文件正常了,不再有莫名其妙的大白边了
不过启动速度慢了不少
发表于 2012-10-19 10:49:49 | 显示全部楼层
Can you post the license file?
发表于 2013-1-15 11:41:29 | 显示全部楼层
Good! Thanks for your sharing!
发表于 2013-4-14 16:29:38 | 显示全部楼层
好东西!!
GMT+8, 2025-10-3 22:47 , Processed in 0.019593 second(s), 7 queries , Gzip On, Redis On.
