查看: 2394|回复: 2
Verilog vs VHDL, which is better????
发表于 2012-10-13 06:50:16 | 显示全部楼层 |阅读模式
发表于 2012-10-13 09:48:38 | 显示全部楼层
They do the same things but verilog is mainly for low level and VHDL is for aliitle higher abstract designs. Verilog syntaxes are like C so learning it is alittle simpler that VHDL. I suggest to learn first verilog then Systemverilog then Systemc. SystemC is more harder and synthesis from it is alittle costly.
发表于 2012-10-13 17:06:35 | 显示全部楼层
楼上正解!
GMT+8, 2025-12-18 22:23 , Processed in 0.015403 second(s), 6 queries , Gzip On, Redis On.
