查看: 1421|回复: 0
[资讯] SST39SF010A单片机技术资料分享
发表于 2012-10-8 14:13:12 | 显示全部楼层 |阅读模式
Organized as 128K x8 / 256K x8 / 512K x8
  Single 4.5-5.5V Read and Write Operations
  Superior Reliability – Endurance: 100,000 Cycles (typical) – Greater than 100 years Data Retention
  Low Power Consumption (typical values at 14 MHz) – Active Current: 10 mA (typical) – Standby Current: 30 μA (typical)
  Sector-Erase Capability – Uniform 4 KByte sectors
  Fast Read Access Time: – 55 ns – 70 ns
  Latched Address and Data
  Automatic Write Timing – Internal VPP Generation
  Fast Erase and Byte-Program
  End-of-Write Detection – Toggle Bit – Data# Polling
  TTL I/O Compatibility
  JEDEC Standard – Flash EEPROM Pinouts and command sets
  Packages Available – 32-lead PLCC – 32-lead TSOP (8mm x 14mm) – 32-pin PDIP
  All devices are RoHS compliant
  All non-Pb (lead-free) devices are RoHS compliant本资料由www.xpjm.net整理提供。
GMT+8, 2025-11-8 12:57 , Processed in 0.201562 second(s), 8 queries , Gzip On, Redis On.
