查看: 14234|回复: 37
[2012-09-08][高频电磁仿真][ANSOFT][HFSS][64bit][14.0.1 PATCH]
发表于 2012-9-8 19:01:39 | 显示全部楼层 |阅读模式
【软件名字】: HFSS
【软件类别】:3d电磁仿真
【软件版本】:14.0.1 64bit for win64
【语言种类】:英文
【软件大小】:83M
【破解方式】:
【内容介绍】:高频电磁仿真软件
【解压密码】:
请注意ATCH后旧破解失效,程式无法运行,还请大牛破解
HFSS1401Win64Patch.part1.rar (14.31 MB , 下载次数: 245 )
HFSS1401Win64Patch.part2.rar (14.31 MB , 下载次数: 234 )
HFSS1401Win64Patch.part3.rar (14.31 MB , 下载次数: 299 )
HFSS1401Win64Patch.part4.rar (14.31 MB , 下载次数: 245 )
HFSS1401Win64Patch.part5.rar (14.31 MB , 下载次数: 221 )
HFSS1401Win64Patch.part6.rar (8.82 MB , 下载次数: 234 )
HFSS 14.0.1 PatchFixes
1. DE26861: Eliminates a false TEM mode validationerror in transient designs
2. DE27165: Corrects HFSS-IE field results fordesigns that incorporate high-loss impedance
boundaries
3. DE28860: Fixes the total field formulation forFEBI radiation boundary conditions
4. DE27402: Addresses an HFSS and ANSYS Mechanicalthermal analysis failure that occurs
when the HFSS design contains a post-processingvariable
5. DE29069: Equivalent circuit export is nowavailable for port-only solutions
6. DE28916: Correct defects in the Edit Sourcessave/load file feature
7. DE27418: Removes a memory leak that occursduring frequency sweeps in HFSS-IE designs
8. DE27005: Fixes an HFSS-IE distributed solutionfailure using the MPI communication protocol
9. DE27696/DE30144: Fixes a failure to import Catiav5 geometry - Note that users will need to install the updated Modeler filesfor CATIA v5 (ACIS 21.0)
10. DE30535: Corrects a false port validation errorin transient designs
11. DE30523: Field reports are now available foreigenmode solutions
12. DE28598: HFSS will now use the correct pulsefunction for lumped ports during a transient
analysis.
13. DE30000: Removes a false HFSS-IE warning thatclaims too many machines are defined
            in the distributed machine configuration
14. DE30011: Eliminates a hang that can occurduring a domain-decomposition analysis in HFSS 14.0
15. DE29930: Corrects an issue in thedomain-decomposition solver that prevents it from converging on a solution
16. DE31082: Corrects an erroneous result producedby the HFSS-IE Physical Optics (PO) solver.
17. DE30500: HFSS will now provide an accurateS-parameter value when the global material environment is defined to besomething other than a vacuum in the presence of an IE radiation boundary.
18. DE28240: Fixes the ProE/PDMLink geometryinterface to HFSS within Workbench.
19. DE31106: A new option, "Enable distributedOptimetrics using DSO License", has been included in the HFSS SolverOptions panel.  See online help for moredetails.
20. DE29136: Links to the online help topic"Differential Pairs in HFSS Transient Network" have been removedsince differential pairs are not available in transient designs.  It is a known issue that this section stillexists in the online help however.Corrects
21. DE31357: Eliminates an interpolating sweepsolution failure that occurs when a variable is selected for derivativecomputation.
22. DE30155: Fixes incorrect ordering of layers ina GDSII import when it has an accompanying tech layer-mapping file.
23. DE29060: Corrects stitching of 2D objects indxf/dwg geometry imports
24. DE31158: Corrects handling of arc segments incertain dxf/dwg geometry imports
25. DE31388: Ensures that H-field results can beplotted and are accurate when post-processing variables are defined in adesign.
26. DE13313: Licenses will no longer be droppedwhen the product is idle unless the user explicitly sets the TIMEOUT value inthe FLEXlm server options file.
27. DE29963: Prevents a batch solution from hangingfor non-administrator accounts utilizing LSF 6.2.
28. DE21208: Fixes a license checkout failure whenthe licenses are node-locked to a USB dongle.
发表于 2012-9-9 10:27:55 | 显示全部楼层
好资料 顶一下
发表于 2012-9-9 14:35:50 | 显示全部楼层
额。。。没准有用
发表于 2012-9-15 21:07:56 | 显示全部楼层
是升级包吗?
发表于 2012-9-16 14:06:01 | 显示全部楼层
推... , 先備著用
发表于 2012-9-17 09:17:40 | 显示全部楼层
Nice ! I will download it!!!!
发表于 2012-10-6 10:22:15 | 显示全部楼层
谢谢分享,希望早日破解!
发表于 2012-10-21 09:49:46 | 显示全部楼层
讚讚讚, Thanksing for sharing
发表于 2012-10-21 18:12:17 | 显示全部楼层
不错不错,谢谢楼主~~~
发表于 2012-10-23 13:49:39 | 显示全部楼层
这个很重要啊
GMT+8, 2025-12-25 07:19 , Processed in 0.116861 second(s), 6 queries , Gzip On, Redis On.
