楼主: Jason.tschen
[原创] CMOS Analog Circuit Design , 3rd edition , Allen
发表于 2013-8-3 20:33:55 | 显示全部楼层
回复 1# Jason.tschen
   nice
发表于 2013-9-7 21:59:33 | 显示全部楼层
谢了楼主
发表于 2013-9-20 10:43:15 | 显示全部楼层
回复 1# Jason.tschen
    这个书很好。顶!
发表于 2013-9-20 10:50:24 | 显示全部楼层
回复 1# Jason.tschen
Amazon 的 review 1:
    Dr. Allen estalished methodological analysis and design principles of CMOS analog circuits, especially in op amps and filters. As the author's publicity tells, this book (and 1st edition) turned a magic of analog circuits and systems to straight forward design flow. As an analog and mixed signal designer, this book is always within my reach on the desk.
发表于 2013-9-20 10:51:12 | 显示全部楼层
回复 301# rfidread
    Amazon review 2:
It is an excellent reference book for the Cmos designers and wannabes, it is a very easy follow through and has very detailed examples, very good.
发表于 2013-9-20 10:53:37 | 显示全部楼层
回复 302# rfidread
    Amazon review 3:
A must have book for any serious analog / mixed signal IC designer. Very detailed and hands-on approach to design tradeoffs. The book was THE Reference for an Austin-based IC company which is already making its 18th year.
发表于 2013-9-20 10:54:23 | 显示全部楼层
回复 303# rfidread
    Amazon review 4:
Especially for undestanding OP-AMP's and Comparators, this book is the best with application and solved examples. Additional to this , explanations about CMOS structures are very usefull...
发表于 2013-9-20 10:55:56 | 显示全部楼层
回复 304# rfidread
      Amazon review 5:
This is one of the best books on CMOS circuit design.  Not a lot of theory stuff, but a lot of practical stuff.  I would highly recommend this book.  For basic this book would be more than sufficient.  Although it does not has any chapters on Low voltage design.  This will become very important because as the geometry gets smaller, the power supply also reduces.  For 0.18u the power supply is about 1.8V.
发表于 2013-9-20 10:56:58 | 显示全部楼层
回复 305# rfidread
     Amazon review 6:
My opinion is that this book is a very useful book on CMOS analog circuit design. If you want to be a good engineer, you should read it because it is easy to understand and has a wide coverage.
发表于 2013-9-20 10:59:15 | 显示全部楼层
回复 306# rfidread
    Amazon review 7:
The book is very good. It is almost brand new and the price is acceptable. It took only one week to get this book.
GMT+8, 2025-12-24 13:52 , Processed in 0.041241 second(s), 2 queries , Gzip On, Redis On.
