查看: 2873|回复: 0
Synopsys Automatic Test Pattern Generation
发表于 2012-8-26 03:45:07 | 显示全部楼层 |阅读模式
Overview
TetraMAX® ATPG automatically generates high quality manufacturing test patterns. It's the only ATPG solution optimized for a wide range of test methodologies and integrated with Synopsys' patented DFTMAX™ compression the leading test synthesis tool. The unparalleled ease-of-use and high performance provided by TetraMAX ATPG allows RTL designers to quickly create efficient, compact tests for even the most complex designs.
https://rapidshare.com/files/3188513929/tx_vD-2010.03-SP2.part1.rar
https://rapidshare.com/files/4649048/tx_vD-2010.03-SP2.part2.rar
GMT+8, 2025-12-29 02:58 , Processed in 0.017629 second(s), 6 queries , Gzip On, Redis On.
