查看: 4830|回复: 11
问一个关于cpu的问题
发表于 2006-12-12 09:26:31 | 显示全部楼层 |阅读模式
现在的cpu都有一到二级的cache,听说cache越大越好.cache的作用,在我看来就是先把要处理的信息存在cache,然后在由cache把信息传给处理部件,由处理部件处理信息,最后输出。
问题:cpu在一个时序中,处理的信息是多大?是一个cache中的所有信息,还是就是一位?如果是所有的信息,那cache就越大越好,如果不是,那cache的作用好像就不那么大了,和内存的作用就差不多了。
谁对cpu 有了解,帮助一下。谢谢!
发表于 2006-12-12 15:43:08 | 显示全部楼层
cache越大命中率就越高,没有命中的还是要从内存中来读
 楼主| 发表于 2006-12-12 17:13:59 | 显示全部楼层
回复 #2 jackzhang 的帖子
.....什么命中率?可以将将cache,或者cpu的处理速度指的是什么?
发表于 2006-12-12 19:02:15 | 显示全部楼层
据我的了解,cache当然越大越好,
发表于 2006-12-13 00:09:47 | 显示全部楼层
cpu 中的内嵌ram比读外部ram快多了,可以理解了吧
发表于 2006-12-13 00:25:36 | 显示全部楼层
非也非也, 物极必反。 太大的cache花费更多的时间寻址,命中率是上去了,速度也下来了。
 楼主| 发表于 2006-12-13 09:23:33 | 显示全部楼层
具我目前所知道的是,cache与cpu内核相连,用的是内部总线,速度比内存的要快。所以越大越好。
但楼上的有几位说的什么命中率,实在不知道是怎么回事?是说也存在什么丢包的类似的现象!
请知道的高手帮忙!
 楼主| 发表于 2006-12-13 15:12:17 | 显示全部楼层
没有人知道?
发表于 2006-12-14 01:00:06 | 显示全部楼层
我说的你也不信, 那就没办法了
那你就看看人家怎么说的咧, 如果还不能理解的话, 我建议你自己动手用晶体管实现一个rom或ram,看看在同一个级别上为什么大容量的memory为什么会比小的慢。 不知道你们用什么工具, cadance估计还在学校的哥们用不了, 那么就用Electric吧, 虽然像玩具但也可以用用阿。
Background
At the heart of most modern computers lies the central processing unit or CPU. It is quite often the fastest and most expensive part of the machine. The CPU operates on data and programs which reside in the computer's main memory chips. The CPU fetches programs from the main memory one instruction at a time and executes them. Quite often, the CPU will have to fetch additional information from the memory, such as data on which a calculation is to be performed. The CPU runs according to a clock. This clock sends out pulses. At each pulse, the CPU will go one step further in this fetch decode execute cycle.
From this very simple sketch, it should be clear that the communication with main memory needs to be very fast: it would be unacceptable if it took a CPU only one clock cycle to execute an instruction, but ten clockcycles to fetch the instruction from main memory. It would be possible to construct memory in such a manner that its access time is equal to that of the CPU's internal registers. This way, a fetch would take only one clock cycle. Unfortunately, such memory is very expensive. For reasons beyond the scope of this text, it would in addition be very complicated, if not impossible, to build a large memory like this. That is why normal computers use slow, cheap dynamic RAM for memory. This RAM is in fact about a factor ten slower than the CPU and it is the biggest bottleneck in modern computers. When buying a computer, it would thus be wise to check out its bus speed instead of the CPU speed.
Principle
To soften the problem outlined above, processors are equipped with a very small amount of expensive on-chip memory, called a cache. The word cache (pronounced 'cash') derives from the French word 'cacher' (to conceal). The cache effectively hides the slower main memory from the CPU. The cache keeps copies of small pieces of data that reside in the main memory. When the CPU requests the data in a certain memory location, the hardware first checks if a copy resides in the cache. If so, the cached data is used. If not, the hardware loads a region of memory into a slot in the cache.
Why cache improves speed
Computer scientists have observed long ago that the memory access behaviour of computer programs is far from random. The CPU does not request values from all over the memory. Instead, there are always some hot spots, some parts of memory that the CPU just keeps accessing repeatedly. This is not surprising since computers are programmed by people that like to organise data and computations into lists, variables, procedures, loops, etc. A program usually executes the same procedures repeatedly, accesses the same variables repeatedly, works its way through lists and pieces of code, etc. This phenomenon is known as locality of reference. In a sentence: locality of reference is the observed statistical property that a program is most likely to request data equal to or close to previously requested data.
With the property of locality of reference in mind, it makes sense to cache an entire region of memory when a location from that region is requested. With luck, the processor will access many locations in this region in the future. Since the cache memory is very fast, this strategy can increase the effective throughput of the CPU considerably.
Caching policy issues
Write Through versus Write Back
Obviously, when the CPU changes data in a cached region, it needs to be written back to main memory at some point in time. There are two policies that can be followed here. They are write back and write through. With write back, a region is marked as 'dirty' once its data have been altered. When the cache is full and regions need to be evicted, the region is written back to memory. If it was not dirty, it is just discarded, since the main memory holds the same copy.With write through, the region is written to memory as soon as it is altered. The former policy holds the best performance increase, since a region may be written many times over for the cost of only one complete memory transfer, whereas the latter costs one complete region transfer per write. In some situations, like multiprocessor environments or situations where consistency and robustness are issues, it might be necessary to write through.
Region replacement
When the cache memory fills up, regions need to be evicted to make room for new ones. The question arises which strategy should be used in order to make the best use of the cache memory. The problem is essentially the same as that of page replacement in a virtual memory system. Belady stated an algorithm in 1966 which Mattson proved to be optimal in 1970. That is, Belady's algorithm causes the least amount of cache misses of all conceivable algorithms. (A cache miss is when a piece of requested data is not in the cache and has to be fetched from memory. The opposite is called a cache hit.) The algorithm is an obscenely simple one: "evict the region that will not be used for the longest period of time". Unfortunately, this algorithm is not causal. It requires knowledge of future events, which makes it impossible to implement (at the time of writing). Many algorithms exist that approach the optimal algorithm, like the Least Recently Used (LRU) algorithm, which evicts the least recently used region, or the First In First Out (FIFO) algorithm and many others. Preferably, hardware designers would use LRU, because it is statistically the closest approximation of the optimal algorithm. Unfortunately, implementing LRU is rather expensive and a compromise is often chosen. To see why, read on!
Mapping
When a region is brought into the cache, there are two conflicting factors involved when choosing a place to store the region. Those factors are efficiency and money. First of all, we could have a fully associative mapping. This means that the region can be placed anywhere in the cache. This would permit an implementation of the LRU algorithm. However, such a cache would make it somewhat difficult to find a specific piece of data within the cache. Since any requested address can be anywhere in the cache, the hardware required to translate linear addresses requested by the CPU to cache locations needs to be fairly sophisticated, read: expensive.
Another strategy is to use direct mapping. In this scheme, each memory region can be in at most one location in the cache. Another way to look at this is that certain memory regions share the same slot in the cache. So if a certain region is in the cache, we always know exaclty where it is, since it has only one place to go. This makes for simple hardware, but it is extremely inefficient. When two regions share the same cache slot they have to be continually swapped in and out if the CPU requires both at the same time. This resembles the thrashing phenomenon found in virtual memory systems that employ a local replacement policy, which was described by Denning in 1968. It is especially unnecessary if the rest of the cache is fully available.
A compromise can be reached in the form of a set-associative mapping. In this scheme, each region has a limited amount (a 'set') of cache regions in which it can reside. The hardware thus doesn't have to look through the entire cache, because it knows there are just a few locations where the sought after region can reside. The first few bits of the absolute memory address are often used as a means to group regions. They are called the tag bits. This way, each chunk of memory maps onto its own set of cache regions, but within that region the mapping is fully associative.
Remark that both direct mapping and set-associative mapping inhibit the implementation of a full LRU replacement strategy. They are cheaper to implement however. An interesting way to look at this is that a direct mapping allows no policy at all. The replacement algorithm is trivial since each requested region has only one way to go. Thus, direct mapping requires no special policy hardware. It also implies one of the worst possible policies.
Region size
Another important design consideration for cache memories is the size of the cached regions. Again, many factors conflict. It is desirable to have a large region size because it increases the chances of another hit on that region. Large regions also make the controlling hardware considerably easier and cheaper. On the other hand, since cache space is limited, a small cache would be more desirable. Further, transferring regions to and from memory takes time; the longer the region, the more time it takes. In practice, finding a good region size is very much an empirical matter. The size of the cache itself is an economical one.
Leftovers
Multiple level caching
Effectively, a computer consists of layer upon layer of caches: the memory caches disk blocks, the on-chip cache caches memory, the registers cache the on-chip cache. There is really no limitation to add yet another layer of cache somewhere. For instance, between the on-chip cache and the main memory we could have another layer of memory that is faster and more expensive than main memory, but cheaper and slower than the on-chip cache. This too comes at an obvious price, but this kind of level 2 caching is quite common. So is level 3 caching. There are some natural limits however. At some point, building a large, fast memory will be cheaper than building dozens of layers of cache.
Translation Look-aside Buffers
In a virtual memory system, which will not be described in this node, a special kind of cache is used in conjunction with the normal cache described above. In a virtual memory system it is necessary to translate virtual addresses to physical ones. It is also necessary to check if a physical address is actually in memory or if it is residing on the hard disk. Because this translation takes time (clock cycles) it pays off to keep the information on recently accessed memory pages in a special cache: the Translation Look-aside Buffer or TLB. On exactly the same grounds of locality of reference, the CPU is likely to need access to the same page in the future as it has just accessed. This is why the page descriptor of such a page is kept in the TLB.
Some typical figures
If you have carefully read the above, you will have noticed that there is much talk about probability and little about certainty. This needs to be stressed: in most of the cases, caching increases speed and in most of the cases, LRU works best. However, these are not laws of nature! There are programs for which LRU performs very poorly, especially when traversing long lists, and there are situations in which caching is slower than direct memory access. These situations do occur in the field so to speak. Be warned. That aside: your average application will have just about 90 percent of cache hits for every memory reference on your average computer. Pretty good! The same holds for the memory by the way: every memory reference that the cache makes in a virtual memory system usually has about 90 percent of hits. The chance of going to the disk is thus very dim. In a properly equipped system that is. This is just to give an impression of course. Your mileage will definitely vary.
Remarks
Caching, and the problems involved, is very similar to the mechanics of paging in a virtual memory system and to the mechanics of block access on disks. In fact, the main memory itself is used for caching disk blocks by the disk driver, since disks are much slower than main memory. Each has its own problems and peculiarities however, but generally, this type of managing limitations in speed and capacity is what makes designing hardware and operating system software so complex, and challenging perhaps. Problems like these are found in operating systems on many, many levels. The manner in which the implementer deals with them makes up for a great deal of the speed and efficiency with which your machine operates. It also makes it very difficult do compare, say a Macintosh with a G4 processor running MacOS X to a PC with an Athlon running Linux.
Another thing to note about the LRU replacement algorithm described above, is that it requires the hardware to keep statistics on each region. It requires continuous knowledge of when each region was used. This causes considerable overhead. Many times a simple approximation is used that will only track the usage of each region for one to four cache misses. Still, updating all the statistics requires complex hardware.
Finally, the computer model described above had to be simplified somewhat. The process of fetching, decoding and executing is a fairly accurate representation of computing on a RISC architecture, like the PowerPC. On a CISC architecture, things are a bit more complex, since each instruction might execute a number of microinstructions, which in turn might access memory.
 楼主| 发表于 2006-12-14 09:36:37 | 显示全部楼层
楼上的高手,我的意思不是不信你。是想知道更详细的东西,为什么慢?
谢谢您给与的资料
GMT+8, 2025-12-21 20:26 , Processed in 0.067263 second(s), 6 queries , Gzip On, Redis On.
