查看: 3662|回复: 1
[求助] the global signoise configuration file 网络拓扑提取出错
发表于 2012-7-17 14:52:08 | 显示全部楼层 |阅读模式
在constraint manager中,在DDR1_A总线的文本框中单击鼠标右键,然后选择SigXplorer命令,弹出:The global Signoise configuration file cds_signoise.cfg cannot be read or is not found in the SIGNOISE path.If the file exists in some other directory,please set a path to that directory in the SIGNOISE env variable.
请问,该怎么解决这个问题?
 楼主| 发表于 2012-7-19 20:05:22 | 显示全部楼层
signoise path 路径错误
GMT+8, 2025-12-16 02:07 , Processed in 0.017430 second(s), 7 queries , Gzip On, Redis On.
