查看: 2781|回复: 2
求助!calibre license相关问题!
发表于 2012-7-10 23:24:55 | 显示全部楼层 |阅读模式
[root@localhost license]# lmgrd -c license.dat
8:01:43 (lmgrd) -----------------------------------------------
8:01:43 (lmgrd)   Please Note:
8:01:43 (lmgrd)
8:01:43 (lmgrd)   This log is intended for debug purposes only.
8:01:43 (lmgrd)   In order to capture accurate license
8:01:43 (lmgrd)   usage data into an organized repository,
8:01:43 (lmgrd)   please enable report logging. Use Macrovision's
8:01:43 (lmgrd)   software license administration  solution,
8:01:43 (lmgrd)   FLEXnet Manager, to  readily gain visibility
8:01:43 (lmgrd)   into license usage data and to create
8:01:43 (lmgrd)   insightful reports on critical information like
8:01:43 (lmgrd)   license availability and usage. FLEXnet Manager
8:01:43 (lmgrd)   can be fully automated to run these reports on
8:01:43 (lmgrd)   schedule and can be used to track license
8:01:43 (lmgrd)   servers and usage across a heterogeneous
8:01:43 (lmgrd)   network of servers including Windows NT, Linux
8:01:43 (lmgrd)   and UNIX. Contact Macrovision at
8:01:43 (lmgrd)   www.macrovision.com for more details on how to
8:01:43 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
8:01:43 (lmgrd)   for your enterprise.
8:01:43 (lmgrd)
8:01:43 (lmgrd)
8:01:43 (lmgrd)
8:01:43 (lmgrd) The license server manager (lmgrd) running as root:
8:01:43 (lmgrd)        This is a potential security problem
8:01:43 (lmgrd)        and is not recommended.
[root@localhost license]#  8:01:43 (lmgrd) FLEXnet Licensing (v10.8.0.6 build 23 943) started on localhost.localdomain (linux) (7/10/2012)
8:01:43 (lmgrd) Copyright (c) 1988-2005 Macrovision Europe Ltd. and/or Macrovis ion Corporation. All Rights Reserved.
8:01:43 (lmgrd) US Patents 5,390,297 and 5,671,412.
8:01:43 (lmgrd) World Wide Web:  http://www.macrovision.com
8:01:43 (lmgrd) License file(s): license.dat
8:01:43 (lmgrd) lmgrd tcp-port 8100
8:01:43 (lmgrd) Starting vendor daemons ...
8:01:43 (mgcld) FLEXnet Licensing version v10.8.0.6 build 23943
8:01:43 (mgcld) cannot open lock file (/var/tmp/lockmgcld): Resource temporaril y unavailable
8:01:43 (mgcld) EXITING DUE TO SIGNAL 41
8:01:43 (lmgrd) Started mgcld (internet tcp_port 34038 pid 32041)
不是很懂?请高手解答!是啥原因???
发表于 2012-7-11 17:05:44 | 显示全部楼层
/var/tmp/lockmgcld 有权限吗? 删掉它试试。
发表于 2012-7-22 22:10:48 | 显示全部楼层
说不定有其他账号启动了license呢
GMT+8, 2025-12-18 14:57 , Processed in 0.017691 second(s), 5 queries , Gzip On, Redis On.
