查看: 2812|回复: 0
hspice仿真过程中出现的离奇现象
发表于 2012-6-29 14:18:08 | 显示全部楼层 |阅读模式
今天仿真一个驱动电路,发现在驱动级的pulse脉冲产生模块里的一个电容会导致不收敛并提示步长太小的问题,电容是600p时候能仿真800u就直接停了,电容是6u的时候只能仿真到200u,去掉电容只能全仿完能,嫉妒离奇,问题是这个电容是用来延迟200n用的我换成反相器延迟也会有不收敛步长太小的问题,费解中,各位大神看看是啥情况啊(另.options method=gear和.options gshunt=1E-12都有了)
**error**  internal timestep too small in transient analysis
          time =  0.11885E-04;  delta =  0.10449E-13;  numnit =  2322
  hspice diagnostic for nonconvergent nodes and elements
                        node    subcircuit       old       new      error
                        name    definition    voltage   voltage   tolerance
                       (net163) main_ckt     1.02e+02   1.20e+02  1.55e+02
                       (net172) main_ckt    -2.11e+03   1.22e+02  1.05e+03
                  (xi10.net047) fliter_g3    1.23e+02   1.24e+02  2.43e+00
                    (xd1.d1:rs) dz2d5macro  -2.12e+03   1.16e+02  1.05e+03
                   (xi10.m3:id) fliter_g3    1.20e+02   1.23e+02  2.49e+01
                   (xi10.m3:is) fliter_g3    1.17e+02   1.19e+02  1.70e+01
                   (xi10.m9:id) fliter_g3    1.15e+02   1.25e+02  7.89e+01
                   (xi10.m9:is) fliter_g3    1.24e+02   1.33e+02  6.42e+01
                    (xd2.d1:i1) dz2d5macro  -2.11e+03   1.22e+02  1.05e+03
                    (xd1.d1:i1) dz2d5macro   1.02e+02   1.20e+02  1.55e+02
                (xm21.mcore:i1) mn600v       1.02e+02   1.20e+02  1.55e+02
                   (xi10.m3:i1) fliter_g3    1.23e+02   1.24e+02  2.43e+00
                   (xi10.m9:i1) fliter_g3    1.23e+02   1.24e+02  2.43e+00
          ***** job aborted
GMT+8, 2025-12-18 18:31 , Processed in 0.016894 second(s), 5 queries , Gzip On, Redis On.
