查看: 2212|回复: 3
ICC problem for GCells too large
发表于 2012-6-22 10:35:42 | 显示全部楼层 |阅读模式
I got the error messages while doing ICC "verify route".Does anybody know the reason?
Error: Database contains global routing GCells that are too large. (ZRT-096)
Error: Failed to load CEL. (ZRT-002)
发表于 2015-4-1 09:54:43 | 显示全部楼层
我也遇到这个问题了,请问楼主解决了吗?我一直不知道怎么解决。。。
 楼主| 发表于 2015-4-1 14:41:53 | 显示全部楼层
回复 2# qchdmb
    you might need change the "gridResolution = 5" in your ICC tech file.
Hopefully, it is workable.
发表于 2015-4-2 16:08:28 | 显示全部楼层
回复 3# wilson168
   gridSolution是制造精度,跟global routing cell没有关系啊,我试过了,不行呢。。。。
GMT+8, 2025-12-19 04:48 , Processed in 0.021894 second(s), 6 queries , Gzip On, Redis On.
