查看: 4294|回复: 0
Phillips Semi / NXP
发表于 2006-12-4 13:27:38 | 显示全部楼层 |阅读模式
Your Responsibilities:
As a Mixed Signal Design Engineer you are member of one or our PMU product development teams. You will be developing digital control circuits for innovative mixed signal high voltage (20 V) CMOS ICs. You fulfill an important role in the integration of these modules into PMUs (top-level design and simulations). The role will cover the full IC design cycle from specification through to testing of engineering samples.
Design & Development
Verification
Quality
Efficiency
Schedule
Coaching
Communication
Your Profile:
Bachelor or Master of Science degree in Electrical Engineering;
Experienced with mixed signal IC design;
Able to build Verilog-AMS models;
Able to run mixed-level simulations;
Experienced with the Cadence and Synopsys tool suite;
A teamworker with a pro-active attitude;
Good verbal and written communication skills
GMT+8, 2025-12-25 17:40 , Processed in 0.015531 second(s), 5 queries , Gzip On, Redis On.
