查看: 13316|回复: 14
design compiler200809安装问题!!
发表于 2012-5-23 15:24:29 | 显示全部楼层 |阅读模式
各位高手,请教一个问题,为什么我按照步骤安装完Design Compiler200809之后,在安装目录dc下只有一个admin文件夹,而没有看到bin呢?
急等!急等!多谢!
发表于 2012-5-23 16:39:45 | 显示全部楼层
post your steps.
 楼主| 发表于 2012-5-23 16:46:53 | 显示全部楼层
回复 2# crazyfind
    前面的问题搞定了,最后在执行dv的时候,提示如下:
root@ubuntu:/usr/synopsys/dc/bin# dv
grep: /etc/redhat-release: No such file or directory
Unable to obtain feature 'Design-Vision ' because:
Error: Software is not licensed for this machine. (SEC-10)
Unable to obtain feature 'Design-Analyzer ' because:
Fatal: At least one of the following must be enabled : Design-Vision, Design-Analyzer. (DCSH-10)
发表于 2013-4-20 22:26:27 | 显示全部楼层
我也碰到了相同的问题。在运行dc dv时
Fatal: Design Compiler is not enabled. (DCSH-1)
wwf@wwf-desktop:~$ dv
Error: Cannot open key file '/home/wwf/synopsys/DC200809/admin/license/key' or a licensing environment parameter has not been set correctly. (SEC-2)
发表于 2013-5-27 13:29:02 | 显示全部楼层
回复 4# eric1810
    解决了吗?我也遇到相同问题
发表于 2013-5-27 15:17:39 | 显示全部楼层
  提示你的license不包含这些Feature
发表于 2013-11-26 19:05:24 | 显示全部楼层
neeed detailed installtion steps
发表于 2013-12-10 23:35:03 | 显示全部楼层
回复 5# cucum13er
    解决了咩有。。我也遇到了
发表于 2014-4-19 02:14:01 | 显示全部楼层
同求解决方法!
发表于 2014-9-17 23:44:30 | 显示全部楼层
from baidu:
add below line to /etc/redhat-release
red hat linux release 3.1 (drupal)
GMT+8, 2025-12-17 01:39 , Processed in 0.026621 second(s), 7 queries , Gzip On, Redis On.
