查看: 4141|回复: 5
[求助] 关于VMM中vmm_channel的问题?
发表于 2012-5-2 22:37:27 | 显示全部楼层 |阅读模式
哪位高人能够解释一下vmm_channel中的active slot到底是个什么东东?有点不明白啊!先拜谢了!!!
 楼主| 发表于 2012-5-2 22:38:37 | 显示全部楼层
自己先顶一下!
发表于 2012-5-5 18:08:26 | 显示全部楼层
用在producer/customer模型中,否则,只需要使用get或peek就可以了。
具体看源代码吧。
发表于 2012-7-27 11:35:51 | 显示全部楼层
An important feature of channels is the active slot. The active slot keeps track of
the currently active transaction, allowing transactors to fill a channel without
retaining references to each transaction. The functions activate(), start(),
complete(), and remove() modify the active slot status so a consumer can
update the transaction status as it is processed. Typically, a channel consumer
should use the active slot and a producer should use put() followed by a
wait_for(ENDED) indication.
看看golden reference中和vmm_channel有关的内容就清楚了。
发表于 2012-8-10 22:49:09 | 显示全部楼层
何必讲的那么抽象呢?其实是SV里面的mailbox的替代物,相较mailbox提供了更多的方法
发表于 2012-11-25 23:06:56 | 显示全部楼层
回复 5# seabeam
   他说的是slot吧。
GMT+8, 2025-12-28 06:24 , Processed in 0.020552 second(s), 6 queries , Gzip On, Redis On.
