查看: 8969|回复: 2
[求助] 请问retrograde well 是什么,具体用于什么情况?
发表于 2012-4-24 12:50:35 | 显示全部楼层 |阅读模式
发表于 2012-4-24 13:15:48 | 显示全部楼层
As semiconductors become more complex and transistors become smaller and smaller, power consumption and heat have become limiting factors to the continued pace of chip design and manufacturing. As millions, or even billions, of smaller and faster transistors get packed on to a single chip the size of a thumbnail, power consumption and the amount of heat generated in the processor core becomes a significant technical challenge. In particular, as chip densities increase, off-state current leakage requires more power and generates more heat, and may present a limit to chip size and integration.
One technique for reducing off-state leakage current is to form a well of dopant in the channel between the source and drain regions of the transistor. For example, in an NMOS device, boron may be implanted into the channel using halo, or pocket, implant methods. Similarly, in a PMOS device, phosphorus may be implanted into the channel using such implant methods. During the source drain anneal, the implanted boron (in an NMOS device) or phosphorus (in a PMOS device) diffuses throughout the channel to form a well having a relatively uniform concentration of boron or phosphorus for some depth below the gate. Such a well(Retrograde Well) affects the resistance of the channel between the source and drain such that off-state leakage current (in other words, leakage current between the source and drain when the transistor is off) is reduced
http://www-inst.eecs.berkeley.edu/~ee143/sp06/lectures/Lec_21.pdf
只找到这些 希望能帮到你~
 楼主| 发表于 2012-4-24 19:24:42 | 显示全部楼层
恩,非常感谢~~只是我看完还是有些不明白,只是知道了它的作用,但是对于它的位置和形成还是一头雾水
GMT+8, 2025-12-15 03:18 , Processed in 0.012567 second(s), 3 queries , Gzip On, Redis On.
