查看: 16411|回复: 62
The Linux Kernel Primer: A Top-Down Approach for x86 and PowerPC
发表于 2006-11-29 21:46:50 | 显示全部楼层 |阅读模式
Learn Linux kernel programming, hands-on: a uniquely effective top-down approachThe Linux® Kernel Primer is the definitive guide to Linux kernel programming. The authors' unique top-down approach makes kernel programming easier to understand by systematically tracing functionality from user space into the kernel and carefully associating kernel internals with user-level programming fundamentals. Their approach helps you build on what you already know about Linux, gaining a deep understanding of how the kernel works and how its elements fit together.One step at a time, the authors introduce all the tools and assembly language programming techniques required to understand kernel code and control its behavior. They compare x86 and PowerPC implementations side-by-side, illuminating cryptic functionality through carefully-annotated source code examples and realistic projects. The Linux® Kernel Primer is the first book to offer in-depth coverage of the rapidly growing PowerPC Linux development platform, and the only book to thoroughly discuss kernel configuration with the Linux build system. Coverage includes
  • Data structures
  • x86 and PPC assembly language
  • Viewing kernel internals
  • Linux process model
  • User and kernel space
  • Interrupts and exceptions
  • Memory allocation and tracking
  • Tracing subsystem behavior
  • I/O interactions
  • Filesystems and file operations
  • Scheduling and synchronization
  • Kernel boot process
  • Kernel build system
  • Configuration options
  • Device drivers
  • And more...
If you know C, this book teaches you all the skills and techniques you need to succeed with Linux kernel programming. Whether you're a systems programmer, software engineer, systems analyst, test professional, open source project contributor, or simply a Linux enthusiast, you'll find it indispensable.
The.Linux.Kernel.Primer.A.Top.Down.Approach.for.x86.and.PowerPC.Architectures.part1.rar
1.91 MB, 下载次数: 363 , 下载积分: 资产 -2 信元, 下载支出 2 信元
The Linux® Kernel Primer: A Top-Down Approach for x86 and PowerPC Architectures
 楼主| 发表于 2006-11-29 21:47:45 | 显示全部楼层
part 2
The.Linux.Kernel.Primer.A.Top.Down.Approach.for.x86.and.PowerPC.Architectures.part2.rar
662.08 KB, 下载次数: 311 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-1-25 10:38:48 | 显示全部楼层
好东西,顶了。
发表于 2007-2-3 15:38:59 | 显示全部楼层
kakakakkakkakakakakkkakkaka
发表于 2007-2-6 23:03:05 | 显示全部楼层
顶了 ~~
发表于 2008-1-3 15:12:02 | 显示全部楼层
up!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2008-1-3 15:19:26 | 显示全部楼层
2up!!!!!!!!!!!!!!!
发表于 2008-1-23 19:40:28 | 显示全部楼层
Appreciate for your sharing !
发表于 2008-2-3 12:11:40 | 显示全部楼层
thanks
发表于 2008-2-3 12:12:28 | 显示全部楼层
up up
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 09:07 , Processed in 0.020264 second(s), 8 queries , Gzip On, Redis On.
