查看: 1978|回复: 1
[求助] 怎么这个时钟程序走的不是很均匀
发表于 2012-4-11 21:22:39 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar fs,fg,ms,mg,ss,sg,s,f,m,i,j,k;
sbit dula=P2^6;
sbit wela=P2^7;
void delay();
void display();
void main()
EA=1;
TMOD=0x01;
ET0=1;
TR0=1;
f=19;
m=0;
s=18;
while(1)
   fs=f/10;
   fg=f%10;
   ms=m/10;
   mg=m%10;
   ss=s/10;
   sg=s%10;
   display();
void timer0()interrupt 1
TH0=(65536-5000)/256;
TL0=(65536-5000)%256;
k++;
if(k%200==0)
m++;
if(m==60)
    m=0;
    f++;
    if(f==60)
         f=0;
         s++;
         if(s==24)
            s=0;
void display()
wela=1;
P0=0xfe;
wela=0;
dula=1;
P0=table[ss];
dula=0;
delay();
wela=1;
P0=0xfd;
wela=0;
dula=1;
P0=table[sg];
dula=0;
delay();
wela=1;
P0=0xfb;
wela=0;
dula=1;
if(m%2==0)
P0=0x09;
else
P0=0;
dula=0;
delay();
wela=1;
P0=0xf7;
wela=0;
dula=1;
P0=table[fs];
dula=0;
delay();
wela=1;
P0=0xef;
wela=0;
dula=1;
P0=table[fg];
dula=0;
delay();
wela=1;
P0=0xdf;
wela=0;
dula=1;
if(m%2==0)
P0=0x09;
else
P0=0;
dula=0;
delay();
wela=1;
P0=0xbf;
wela=0;
dula=1;
P0=table[ms];
dula=0;
delay();
wela=1;
P0=0x7f;
wela=0;
dula=1;
P0=table[mg];
dula=0;
delay();
void delay()
for(i=0;i<30;i++)
   for(j=0;j<20;j++);
发表于 2013-4-28 11:54:25 | 显示全部楼层
晶振有问题吧?
GMT+8, 2025-12-27 15:08 , Processed in 0.026686 second(s), 8 queries , Gzip On, Redis On.
