查看: 11554|回复: 28
An Introduction to HFSS: Fundamental Principles, Concepts, and Use
发表于 2012-4-7 05:13:09 | 显示全部楼层 |阅读模式
Contents:
___________________
Fundamentals of HFSS
The mathematical method used by HFSS
The adaptive solution process and itsimportance to HFSS
The computational volume and its parts
The six general steps in an HFSS simulation
The three solution types
HFSS Boundaries
Boundaries in HFSS and the need for them
The available boundaries within HFSS
Boundaries Examples – Perfect ElectricConductor
Boundaries Examples – Radiation Boundary
Boundaries Examples – Perfectly MatchedLayer (PML)
Boundaries Examples – Finite Conductivity
Boundaries Examples – Layered Impedance
Boundaries Examples – Impedance
Boundaries Examples – Symmetry
Boundaries Examples – Lumped RLC
Boundaries Examples – Master/Slave
Boundaries Examples – Screening Impedance
Boundaries Examples – Perfect H
Applyingboundaries
HFSS Excitations
Excitations in HFSS
Excitations Example – Wave Ports
Excitations Example – Lumped Ports
The difference between lumped ports andwave ports
HFSS Solution Setup
The solution frequency
The Delta S setting
The maximum refinement per pass and maximum numberof passes settings
The different frequency sweeps
The differences between local, remote and DSOsolutions
HFSS Modeling GUI Basics
The modeling GUI windows
The various hotkeys
Snapping on to a point
Assigning boundaries in the GUI
Assigning How do I assign a Driven Modal Solutionexcitations in the GUI
Assigning Driven Terminal Solution excitations inthe GUI
Assigning and creating materials
Creating variables
HFSS Post-Processing
Plotting S-parameter results
Exporting touchstone files
Advanced plotting of results
Plotting antenna results
Plotting field results
Creating animations
Appendix
Additional reading materials
HFSSintro.rar
1.48 MB, 下载次数: 360 , 下载积分: 资产 -2 信元, 下载支出 2 信元
10
发表于 2012-4-13 20:19:47 | 显示全部楼层
这是HFSS的帮助文件吗
发表于 2012-4-13 20:58:19 | 显示全部楼层
Thanks very much
发表于 2012-4-13 20:59:31 | 显示全部楼层
Thanks very much
发表于 2012-4-14 16:03:56 | 显示全部楼层
thank you so much I really need it
发表于 2012-4-15 09:29:54 | 显示全部楼层
good, thanks a lot for your sharing.hope it can help us to know what is hfss
发表于 2012-5-24 13:57:38 | 显示全部楼层
I am expecting it for sometime; really helpful. Thanks.
发表于 2012-11-22 20:42:02 | 显示全部楼层
下来看看。。。。。。。。。
发表于 2012-11-22 23:37:48 | 显示全部楼层
expected good material
发表于 2012-11-24 17:08:22 | 显示全部楼层
好东西 谢谢
GMT+8, 2025-12-27 14:46 , Processed in 0.021968 second(s), 6 queries , Gzip On, Redis On.
