查看: 3657|回复: 2
[求助] Error: List of pins mismatched in logic and physical libraries
发表于 2012-4-1 15:06:19 | 显示全部楼层 |阅读模式
Error: List of pins mismatched in logic and physical libraries (LIBCHK-213)
Logic library:    PF32K09E
Physical library: /home/jingjing/syn0426/mcu_lef/flash1
                                          Pin direction           Pin type
Cell name                    Pin name    Logic   Physical     Logic         Physical
PF32K09E                     VDD         inout   Input/Output signal        power
                             VSS         inout   Input/Output signal        ground
Logic library:    S018VRLDO_max
Physical library: /home/jingjing/syn0426/mcu_lef/LDO
S018VRLDO                    VOUT18B     output  Output      signal         power
                             VDDA30      inout   Input/Output signal        power
                             VDDA18      inout   Input/Output signal        power
                             VDDD        inout   Input/Output signal        power
                             VDDD2       inout   Input/Output signal        power
                             VSSA        inout   Input/Output signal        ground
Logic library:    SP018_V1p4_max
Physical library: /home/jingjing/syn0426/mcu_lef/SMICIO6M
PVSS3AP                      SAVSS       output  Output      signal         ground
PVDD3AP                      SAVDD       output  Output      signal         power
PVSS1AP1                     SVSS1AP1    output  Output      signal         ground
PVSS1AP                      SVSS1AP     output  Output      signal         ground
PVDD1AP1                     SVDD1AP1    output  Output      signal         power
PVDD1ANP                     SVDD1ANP    output  Output      signal         power
PVSS1ANP                     SVSS1ANP    output  Output      signal         ground
PVDD1AP                      SVDD1AP     output  Output      signal         power
PVSS3CAP                     SAVSS       output  Output      signal         ground
PVDD3CAP                     SAVDD       output  Output      signal         power
PVDD1CAP                     SVDD1CAP    output  Output      signal         power
PVDD1CAP1                    SVDD1CAP1   output  Output      signal         power
PVSS1CAP                     SVSS1CAP    output  Output      signal         ground
PVSS1CAP1                    SVSS1CAP1   output  Output      signal         ground
PVDD1                        VDD         output  Output      signal         power
PVSS1                        VSS         output  Output      signal         ground
PVSS3                        VSS         output  Output      signal         ground
我是用ICC做的,logic library是db文件,所以不能打开修改,这个问题严重吗?请大侠们帮忙出出主意,不胜感激!!这个是不是只改pin direction就可以了,pin type没关系吗?顺便求db转lib的命令~~~
发表于 2012-4-11 17:59:20 | 显示全部楼层
kan bu dong , neng jie shi yi xia ma
发表于 2012-4-14 01:24:40 | 显示全部楼层
看起來只是 power/ground 定義的不同,好像是 .db 裡把 power/ground 的 pin 也加進去了,
找找看有沒有 .lib 可以修改再重新 complied 成 .db。
GMT+8, 2025-12-21 13:01 , Processed in 0.020647 second(s), 5 queries , Gzip On, Redis On.
