查看: 7669|回复: 12
[招聘] Texas Instrument北京研发中心招聘Digital Designer(内部推荐)
发表于 2012-3-21 17:37:24 | 显示全部楼层 |阅读模式
职位描述如下:
The ideal candidate will have a Master’s degree, along with a theoretical background and practical experience of 2 years or more in the mixed-signal IC design industry. Competency in digital design, system implementation, and understanding fundamental digital circuits including finite state machines, synchronous/asynchronous de-bounce and de-glitch circuitry, clock and reset strategies, binary/gray code encoding, and serial communication interfaces (I2C/SPI) is necessary.
This engineer must be capable of RTL design using Verilog/VHDL, verification using automatic checking testbenches, code coverage analysis, synthesis, scan insertion, place and route, logical equivalence checking, static timing analysis, and interfacing with Cadence analog tools such as Virtuoso.
This engineer must possess good communication (written, spoken, listening) skills and the ability to work in a cross-functional team to develop world class mixed-signal ICs. The ability to accurately and clearly communicate capabilities and results to customers is also required.
Other responsibilities include:
• In the planning phase, this engineer must be able to quickly understand functionality of existing circuit solutions and identify/propose unique, high value solutions.
• Understanding IC fabrication processes and digital library deliverables and translating process capabilities and system level requirements into real world designs.
• Quickly generating prototype simulation models and testbenches for quick feasibility analysis
• Designing a comprehensive verification infrastructure for thorough analysis of RTL design
• Understanding of synthesis steps and ability to debug RTL implementations that are not compatible with synthesis
• Understanding of scan synthesis and proper digital scan circuit implementations
• Implementation of floorplan, power plan, clock tree structures
• Static timing analysis, constraint refinement, and timing closure
• Logical equivalence checking
• Creating schematic and layout databases compatible with the analog design tools (Cadence Virtuoso)
• Proficient use of oscilloscopes, arbitrary waveform generators, and measurement devices for laboratory evaluation of new silicon and competitive analysis
简历接收邮箱:
ti_recruiter@hotmail.com
发表于 2012-3-21 17:59:58 | 显示全部楼层
请问有没有模拟电路设计的职位?
做实习生可以么?
发表于 2012-3-21 20:40:01 | 显示全部楼层
多少大洋,不要觉得我们俗,按您这要求,几乎就是senior manager 的招聘要求啊,design PRD,coding,simulation,synthesis,timing,甚至floor plan,Texas招聘都这么威武,还是两年经验,不知是不是这些都精通才行,如果要求都精通,那您可真开不起待遇,这是senior 的水准
 楼主| 发表于 2012-3-22 00:08:27 | 显示全部楼层
回复 2# ilikeeatingcake
    TI北京也有一些Analog Design的职位发布,我会陆续贴出来。
    如果你有兴趣想来TI作实习生,无论是数字还是模拟职位,请把的简历发给我,我会帮你争取面试机会!
 楼主| 发表于 2012-3-22 18:07:02 | 显示全部楼层
已经投简历的筒子们请耐心等待。。。
 楼主| 发表于 2012-3-31 16:37:20 | 显示全部楼层
顶一顶!
发表于 2012-4-1 12:50:20 | 显示全部楼层
回复 1# TI_Recruiter
LZ好,数字后端要吗?
 楼主| 发表于 2012-4-3 23:02:08 | 显示全部楼层
回复 7# X6J6P6
    不好意思,后端工程师职位目前没有空缺。
    欢迎数字前端工程师投简历!
 楼主| 发表于 2012-4-13 15:38:47 | 显示全部楼层
顶一顶!
发表于 2012-4-14 16:50:59 | 显示全部楼层
这些都是基数要求, 和management 没关系啊, 最多是技术fellow, 呵呵
GMT+8, 2025-12-17 06:42 , Processed in 0.025492 second(s), 6 queries , Gzip On, Redis On.
