查看: 4957|回复: 5
centos4.8安装ic610失败。各位高手帮帮忙!
发表于 2012-3-6 20:16:35 | 显示全部楼层 |阅读模式
服务器系统是centos4.8
已经按照网上的教程安装了ic610和mmsim101
该配置的按照教程也都配置了。
打开终端直接显示的是
declare -x CDS_LIC_FILE="5280@localhost"
declare -x CDS_Netlisting_Mode="Analog"
declare -x CDS_ROOT="/home/yqli/eda/ic610"
declare -x COLORTERM="gnome-terminal"
declare -x DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-SE77vmGyFQ"
declare -x DESKTOP_SESSION="default"
declare -x DISPLAY=":0.0"
declare -x GDMSESSION="default"
declare -x GNOME_DESKTOP_SESSION_ID="Default"
declare -x GNOME_KEYRING_SOCKET="/tmp/keyring-xb2dPx/socket"
declare -x GTK_RC_FILES="/etc/gtk/gtkrc:/root/.gtkrc-1.2-gnome2"
declare -x G_BROKEN_FILENAMES="1"
declare -x HISTSIZE="1000"
declare -x HOME="/root"
declare -x HOSTNAME="localhost.localdomain"
declare -x INPUTRC="/etc/inputrc"
declare -x KDEDIR="/usr"
declare -x LANG="en_US.UTF-8"
declare -x LESSOPEN="|/usr/bin/lesspipe.sh %s"
declare -x LM_LICENSE_FILE="/home/yqli/eda/ic610/share/license/license.dat"
declare -x LOGNAME="root"
declare -x LS_COLORS=""
declare -x MAIL="/var/spool/mail/root"
declare -x MMSIM_ROOT="/home/yqli/eda/mmsim61"
declare -x MOZILLA_HOME="/usr/bin/netscape"
declare -x OA_HOME="/home/yqli/eda/ic610/OA"
declare -x OLDPWD
declare -x PATH="/home/yqli/eda/mmsim61/tools/bin:/home/yqli/eda/mmsim61/tools/spectre/bin:/home/yqli/eda/ic610/tools/bin:/home/yqli/eda/ic610/tools/dfII/bin:/usr/lib64/qt-3.3/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/root/bin"
declare -x PWD="/root"
declare -x QTDIR="/usr/lib64/qt-3.3"
declare -x QTINC="/usr/lib64/qt-3.3/include"
declare -x QTLIB="/usr/lib64/qt-3.3/lib"
declare -x SESSION_MANAGER="local/localhost.localdomain:/tmp/.ICE-unix/26878"
declare -x SHELL="/bin/bash"
declare -x SHLVL="2"
declare -x SSH_AGENT_PID="26908"
declare -x SSH_ASKPASS="/usr/libexec/openssh/gnome-ssh-askpass"
declare -x SSH_AUTH_SOCK="/tmp/ssh-sbETm26878/agent.26878"
declare -x TERM="xterm"
declare -x USER="root"
declare -x WINDOWID="18874449"
declare -x XAUTHORITY="/root/.Xauthority"
然后键入lmli
[root@localhost ~]# lmli
19:10:33 (lmgrd) -----------------------------------------------
19:10:33 (lmgrd)
Please Note:
19:10:33 (lmgrd)
19:10:33 (lmgrd)
This log is intended for debug purposes only.
19:10:33 (lmgrd)
In order to capture accurate license
19:10:33 (lmgrd)
usage data into an organized repository,
19:10:33 (lmgrd)
please enable report logging. Use Macrovision's
19:10:33 (lmgrd)
software license administration
solution,
19:10:33 (lmgrd)
FLEXnet Manager, to
readily gain visibility
19:10:33 (lmgrd)
into license usage data and to create
19:10:33 (lmgrd)
insightful reports on critical information like
19:10:33 (lmgrd)
license availability and usage. FLEXnet Manager
19:10:33 (lmgrd)
can be fully automated to run these reports on
19:10:33 (lmgrd)
schedule and can be used to track license
19:10:33 (lmgrd)
servers and usage across a heterogeneous
19:10:33 (lmgrd)
network of servers including Windows NT, Linux
19:10:33 (lmgrd)
and UNIX. Contact Macrovision at
19:10:33 (lmgrd)
www.macrovision.com for more details on how to
19:10:33 (lmgrd)
obtain an evaluation copy of FLEXnet Manager
19:10:33 (lmgrd)
for your enterprise.
19:10:33 (lmgrd)
19:10:33 (lmgrd)
19:10:33 (lmgrd)
19:10:33 (lmgrd) The license server manager (lmgrd) running as root:
19:10:33 (lmgrd)
This is a potential security problem
19:10:33 (lmgrd)
and is not recommended.
license manager: can't initialize: No SERVER lines in license file.
License path:
FLEXnet Licensing error:-13,66
For further information, refer to the FLEXnet Licensing End User Guide,(神马意思???)
available at www…….
然后键入icfb&
[root@localhost ~]# icfb&
[1] 27400
cadence能够打开。但是不能新建cell。新建cell就会出现框框
(delicense-7)couls not get a lincense for schematics L
would you like to try to get a high-tiered license to run the product?
cadence的显示框里会显示*warning*(iclic-3)could not get license irtuoso-schematic-editor-L
各位高手们。帮忙看看。这是什么问题????
boss跟我说是mark地址的没有设置好的问题。请问这个是怎么设置的?
说是在开机的时候才能看到或者找到。
我差了很多资料。还是不懂。
希望大家能帮帮我。谢谢了。很急
 楼主| 发表于 2012-3-6 20:27:22 | 显示全部楼层
我是不是还要安装Calibre???????我没安装这个
发表于 2012-3-7 09:39:42 | 显示全部楼层
 楼主| 发表于 2012-3-7 20:11:12 | 显示全部楼层
回复 3# yulizi
    您好,您知道需要怎么设置系统才能解决这个问题呢?多谢
发表于 2012-3-7 20:36:17 | 显示全部楼层
普通用户启动lmgrd
license.dat文件有效第一行应该是SERVER <hostname> <xxxxxxxx> <port>
发表于 2012-12-11 13:53:09 | 显示全部楼层
额……也遇到类似问题了 有没有能解决的大侠?
GMT+8, 2025-12-18 07:21 , Processed in 0.020801 second(s), 5 queries , Gzip On, Redis On.
