楼主: zzone
VCS2011.03在CentOS5.6上无法运行。。。
发表于 2012-3-20 15:27:33 | 显示全部楼层
centos6.2 都可用 内核2.6.32
发表于 2012-5-8 07:26:09 | 显示全部楼层
升级到5楼的版本
发表于 2012-5-8 09:24:35 | 显示全部楼层
現在有多少 eda tool 可以在 6.2 上run ?
发表于 2012-5-12 14:03:07 | 显示全部楼层
Algorithm for usage of VCS 2011+ on CentOS 6.0+ =>
1. In "/etc/redhat-release"  being "root / sudo(if applicable)" ==>
    -> Comment the existing version using "#" character in the above file [without quotes]
    -> Enter the following : "CentOS release 5.7 (Final)" <- Without quotes as the very "First Line"
    -> Save and exit as root (NO re-boot is required)
    -> Start using the VCS 2011+ assuming proper license is available for that machine / (over)network
2. After sims complete, either being bored of VCS(or Synopsys in general) or job complete =>
    -> Replace the original CentOS version line in the above file as the very "First Line"
    -> Retain the CentOS release 5.7 (Final) line, but commented using "#" character and as second(2nd)
         line without quotes as well
    -> Save and exit as root (or sudo if applicable)
3. Use CentOS normally as usual
4. Don't ever "upgrade/update/install" anything in the present OS(6.0+) when above file has Centos 5.7[+/-]
     as entry, otherwise even the kernel will get overwritten if updated while having 5.7 as entry even
     through the OS might be 6.0+
5. If Kernel of Centos 6.0+ is overwritten with kernel of Centos 5.7+, NO issues : =>
    -> Using YUM,  "re-install" kernel to come back to Centos 6.0+(6.1/6.2/6.x) and reboot
    -> All is well :-D
6. Take extreme care of => "/etc/redhat-release" file in RHEL/CentOS environment !!!
7. Even RHEL engineers can use the above algorithm because => CentOS is a carbon copy of => RHEL
发表于 2012-11-26 12:27:09 | 显示全部楼层
和RHEL应该一样吧,RHEL5跑这个版本不会有问题呀
发表于 2018-7-31 10:37:57 | 显示全部楼层
请问楼主这个问题是怎么解决的,我用centos6.5/6.9/7,在虚拟机上vcs可以成功运行,装在硬盘上的系统就是不行,都提示Sorry, Linux version **** is not supported。
发表于 2020-7-9 15:48:48 | 显示全部楼层
留给后来有需要的朋友:
vi `which vcs`
#VCS_ARCH=`${UNAME}` 2>&1
#VCS_RNAME=`${UNAME} -r`;
#VCS_MNAME=`${UNAME} -m`;
VCS_ARCH="linux64"
VCS_MNAME="x86_64";
发表于 2021-2-22 17:50:29 | 显示全部楼层
celestin2011 发表于 2020-7-9 15:48
留给后来有需要的朋友:
vi `which vcs`
您好,我也遇到了同样的问题,你这几行是添加到环境变量说明里面去吗,我加进去之后还是无法解决,能不能说的详细一些,谢谢。
发表于 2021-3-10 20:13:14 | 显示全部楼层
beargebinjie 发表于 2021-2-22 17:50
您好,我也遇到了同样的问题,你这几行是添加到环境变量说明里面去吗,我加进去之后还是无法解决,能不能 ...
vi `which vcs`  运行这个命令,编辑vcs启动脚本文件,按我那个进行注释并增加,不是修改环境变量
GMT+8, 2025-12-9 09:30 , Processed in 0.016484 second(s), 3 queries , Gzip On, Redis On.
