查看: 3285|回复: 2
[求助] IC610仿真的时候出现以下错误信息,求助
发表于 2012-2-15 16:42:58 | 显示全部楼层 |阅读模式
*Error* Unable to locate 'spectre' executable in the specified path.
        To set the correct path, use setShellEnvVar() in CIW.
是要修改环境变量还是什么的,不是很懂,求大神指教。。。
 楼主| 发表于 2012-2-15 20:53:27 | 显示全部楼层
# lmstat -a | grep AnalogUsers of Analog_Design_Environment_L:  (Uncounted, node-locked)
Users of Analog_Design_Environment_XL:  (Uncounted, node-locked)
Users of Analog_Design_Environment_GXL:  (Uncounted, node-locked)
[root@localhost nieguangzhen]# spectre -Wbash: spectre: command not found
# echo $PATH
/usr/kerberos/sbin:/home/eda/mmsim61/tools/bin:/home/eda/mmsim61/tools/spectre/bin:/home/eda/ic610/tools/bin:/home/eda/ic610/tools/dfII/bin:/home/eda/mmsim61/tools/bin:/home/eda/mmsim61/tools/spectre/bin:/home/eda/ic610/tools/bin:/home/eda/ic610/tools/dfII/bin:/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/nieguangzhen/bin
 楼主| 发表于 2012-2-15 20:55:16 | 显示全部楼层
自己顶一下,高手们,赶快帮忙啊
GMT+8, 2025-12-25 14:57 , Processed in 0.019687 second(s), 6 queries , Gzip On, Redis On.
