查看: 24304|回复: 25
[求助] 如何使用Milkyway 产生memory的Milkway lib
发表于 2012-2-6 15:21:58 | 显示全部楼层 |阅读模式
各位大侠你们好!
现在我需要产生memory的Milkway lib,具体流程如下,请各位大侠看下问题出在哪儿。
1. create a Milkyway lib
TF file
scc65nll_vhs_8lm_1tm.tf
返回的结果为:
Technology file scc65nll_vhs_8lm_1tm.tf has been loaded successfully.
axtfInitializeMainTable
Error: Failed to build technology table from scc65nll_vhs_8lm_1tm.tf. (MW-019)
Cannot perform requested operation.
axBuildALayer failed for PRBoundary!
2. LEF to Milkyway
设置如下
Tech LEF file: scc65nll_vhs_8lm_1tm.lef
Cell LEF file: S65NLLHS1PH_X65Y1D38.lef
Map file: gds2InLayer.map
返回的结果为:
Starting to read LEF file ...
WARNING : LEF NAMESCASESENSITIVE ON is inconsistent with library case sensitive OFF.
Calling LEF IN API exit handler ...
Read LEF completed
Milkyway lib的文件夹下,并没有CELFRAM两个文件夹。
我不知道我的流程中哪一步出了问题,我觉得可能是map file或者LEF file选择的不对。
期待你们的回复,谢谢!
发表于 2012-2-6 16:52:12 | 显示全部楼层
memory有lef的话,可以LEF to Milkyway的方式进行
发表于 2013-1-15 09:12:44 | 显示全部楼层
回复 1# ouyds001
    兄弟你有milkyway这个软件吗?可以共享一下吗?谢谢。
发表于 2013-1-16 09:50:27 | 显示全部楼层
回复 1# ouyds001
    我现在也是在lef 到milkyway的有问题啊。
Capacitance models should be loaded with a TLU+ file later.
Start to load technology file .sc9_tech1.lef.tf.
Technology file .sc9_tech1.lef.tf has been loaded successfully.
ERROR: Parser Error At Line 16, Last token was <
       Caused By:<syntax error>
ERROR: Parser Error At Line 17, Last token was <
ERROR: Parser Error At Line 18, Last token was <
ERROR: Parser Error At Line 19, Last token was <
发表于 2013-1-16 09:56:39 | 显示全部楼层
回复 2# damonzhao
    版主,我就是用LEF到milkyway的自动化流程,但是有很多错误啊。
ERROR: Parser Error At Line 20, Last token was <
>>> Read Cell LEF File "/mnt/hgfs/share/sram/sram_sp_hdf.lef" ...
Parser Warning At Line 18, Last token was <sram_sp_hdf>,
       Caused By:<FOREIGN in VIA is obsolete in LEF 5.6.It will be ignored>
Error: Failed to get layer M4 in library. (MWLIBP-055)
Error: Failed to get layer M3 in library. (MWLIBP-055)
Error: Failed to get layer M2 in library. (MWLIBP-055)
Error: Failed to get layer M1 in library. (MWLIBP-055)
Re-mark cell sram_sp_hdf's type as MacroCell.
Done
Read LEF completed.
Extracting blockage/pin ...
------ new BPV starts ... -----
Marking EEQ ports in each cell.
       Processing cell [sram_sp_hdf_26155.CEL] ...
** (Delete Cell) ** (cell name = sram_sp_hdf_26155, view name = FRAM) does not exist.
(Macro Instance Object Layer) .....................
Port WEN does not exist in cell sram_sp_hdf
Port Q[7] does not exist in cell sram_sp_hdf
发表于 2013-1-16 10:12:38 | 显示全部楼层
回复 6# lizhaohong520@
    首先看看提示的lef语法错误是什么
其次,debug一下你用的map文件。
发表于 2013-1-16 22:34:39 | 显示全部楼层
怎么都是smic65ll,现在,
先load astro、apollo tf ,建库,然后read_lef , 不要带tech lef,
发表于 2013-1-17 10:55:13 | 显示全部楼层
回复 8# icfbicfb
    版主你这个讲得比较飘渺,请问有类似的脚本和资料吗?谢谢!
发表于 2013-1-17 11:01:59 | 显示全部楼层
回复 7# damonzhao
    我的tf file的lef文件是工厂给的,怎么会提示语法错误,这个是怎么搞?我去研究一下,谢谢啊!
发表于 2013-1-30 09:12:12 | 显示全部楼层
回复 4# lizhaohong520@
    Starrc这个软件里面有.你到论坛里面搜搜 .
GMT+8, 2025-9-17 03:30 , Processed in 0.022290 second(s), 5 queries , Gzip On, Redis On.
