楼主: fishpan
求一个lmgrd和cdslmd的低版本
发表于 2012-1-19 18:38:21 | 显示全部楼层
回复 10# fishpan
I understand that IC510+MMSIM10.1 license works using "older version lmgrd and cdslmd" provided by abad1349. I have very same problem to solve. Thanks to abad1349 for his kindness.
Are you replaced MMSIM10.1's newer version cdslmd by overwriting it in its original installed place with older version one.
Also are you replaced newer lmgrd in its original installed place with the older version one. Or you put old lmgrd to a separate file location and changed its calling directory in .bashrc file.
Are lmhostid, lmpath, lmremove, lmreread, lmstat, lmswitch, lmswitchr, lmutil and lmver need to be left alone as they were and do not cause any problem?
Did you applied any patch to MMSIM10.1?
thank you very much for any information you would provide. If it works finally I need to catch up 3 weeks sleeplessness.
据我所知,IC510+ MMSIM10.1许可使用“旧版本的lmgrd和cdslmd”abad1349提供。我有同样的问题要解决。感谢他的好意abad1349。
你取代MMSIM10.1的新版本,它覆盖在其原来的安装与旧版本之一cdslmd。
此外,取代在其原来的安装与旧版本的新的lmgrd。或者你把旧的lmgrd到一个单独的文件位置,并改变它的调用目录。bashrc文件。
lmhostid,lmpath,lmremove,lmreread,lmstat,lmswitch,lmswitchr,lmutil的和lmver需要独处,因为他们并不会造成任何问题吗?
你任何修补程序应用到MMSIM10.1?
非常感谢你,为你会提供的任何信息。如果它的工作原理,最后我需要赶上3个星期失眠。
 楼主| 发表于 2012-4-8 23:13:53 | 显示全部楼层
Sorry I did not notice your informantion for so long. I did not replaced any original files, I only copy the newer lmgrd and cdslmd to a new folder and changed the first line of the license file, such as "/the new folder/lmgrd " and "/the new folder/cdslmd ".
I have not find any problem yet .
The MMSIM10.1 must be carcked.
 楼主| 发表于 2012-4-8 23:19:34 | 显示全部楼层
I downloaded the license file and MMSIM10.1 from this Website,  they must match each other to work properly, I think.
发表于 2012-6-4 08:45:02 | 显示全部楼层
学习了,谢谢!
发表于 2012-6-27 20:29:54 | 显示全部楼层
学习啦
发表于 2012-8-10 09:08:18 | 显示全部楼层
Fishpan
能分享一下您的IC5141+MMSIM10 的设置、License、安装步骤 吗? 我急需相同的设置。 谢谢了!
发表于 2013-11-25 10:02:35 | 显示全部楼层
回复 8# abab1394
float lic是什么类型的LIC
发表于 2014-1-20 14:10:24 | 显示全部楼层
學習
恭喜樓主
发表于 2015-6-16 19:00:21 | 显示全部楼层
同求了好久
发表于 2016-12-27 16:36:24 | 显示全部楼层
同求了好久
GMT+8, 2025-12-29 01:25 , Processed in 0.021744 second(s), 4 queries , Gzip On, Redis On.
