查看: 2480|回复: 1
[招聘] 【社会招聘】全球著名美资IC公司LSI上海研发中心2011年12月最新热招职位!!!
发表于 2011-12-19 11:02:13 | 显示全部楼层 |阅读模式
LSI上海研发中心正在扩张,目前有很多职业发展机会,欢迎有志之士加入!有意者,请将简历发至:Tracey.zheng@lsi.com
如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.
也可加我msn: zql975504@hotmail.com
或者微博啊:http://www.weibo.com/u/1752448637
LSI上海研发中心位于徐汇区中山南二路徐汇苑大厦(8万人体育场对面)
1.
Digital Design Engineer-Shanghai
Job Responsibilities
Working with an Architecture/Algorithm Development Team to finalize system architecture
for optimal implementation of digital signal processing algorithms, including architectural
definition and tradeoffs, die size, power estimation.
Skill required:
Digital logic design, verilog coding, logic synthesis, both RTL and gate level verification,
formal verification and static timing analysis. Unix shell, Perl scripting, C/RTL co-simulation.
Sound theory background  of communication and Digital signal processing.
2.
ASIC Customer Engineer-Shanghai (本年度最后一个,有兴趣的同学要快啊!)
Job Description
- LSI Corporation offers an excellent opportunity to contribute to a team environment and to grow personal career path. You will be working with internal and external customers to develop state of the art IC solutions utilizing LSI's leading edge CMOS cell-based ASIC technologies. You will have responsibility for ASIC designs through all of the key development and implementation phases including RTL analysis, synthesis, design optimization, timing verification, simulation, test insertion, physical design, vector generation, and post-prototype test support. Candidates will have opportunity to work on the latest 40nm/28nm designs.
Requirements/Qualifications (Education)
Education: BS/MS Electrical, Computer Engineering or Equivalent
- Candidates have ONE OR MORE good skill sets of the following areas are highly encouraged to apply:
- RTL Analysis/Synthesis/STA: The ideal candidate should have strong skills for the front-end of design
- implementation which includes RTL Analysis, Synthesis Strategies, and STA setup for complex ASIC
- environments. This would include strategies for power management.
- OR
Physical Design Implementation: The ideal candidate should be strong in the Physical Design (at least at block level) which includes floor planning, design closure, & STA. Having strong DRC & LVS skills are a plus.
- Synopsys Astro/ICC experience a plus. Having Mentor Calibre skills a plus.
- OR
- Physical Verification: The ideal candidate should have in-depth understanding of transistor level IC fabrication process, familiar with major foundries(TSMC or SMIC) runsets and verification flow, custom layout experience is a plus, successfully done LVS/DRC/ERC/Antenna check for multiple tapeouts is a strong plus. Understanding of DFM is a plus. Calibre experience is a plus.
- OR
- DFT: The ideal candidate should be strong in all DFT (Design for Test) for all aspects. This would include
- scan/TDF, TestKompress, MEMBIST/BISR, JTAG and etc. Having STA skills is a plus for all aspects of test. Responsible for support / debug of customer designs after delivery of prototypes
3.
Signal Integrity & Application Engineer
(New!!!)
DESCRIPTION OF DUTIES IN ADDITION TO THOSE IN JOB DESCRIPTION:
This position will define SI requirements on advanced memory interface solutions including
DDR3/4, RLDRAM III and ONFI 2.2 NAND Flash interfaces. Work in a co-design environment
by providing specifications to IO and package designers. Develop IP implementation
guidelines based on feasibility analysis and support internal design teams. Provide complete
application support to customers by providing SI Kits, Timing Budgets and System Design
Application Notes.
PREFERRED EXPERIENCE:
- Education Requirements: MSEE with 5 or BSEE with 7 years experience in high speed
interface design and signal integrity.
- Hands on experience with high speed interfaces (DDR1/2/3, RLDAM II, QDR SRAM,
Flash, USB) implementation and hardware system experience is a must..
- Experience in Serial Interface architecture, protocols, Backplane design/analysis is
preferable.
- System Signal Integrity analysis experience with HSPICE is must and familiarity with tools
such as Agilent ADS, Sigrity Power-SI, Ansoft HFSS, Apache tools.
- Knowledge of IBIS modeling, board & package model extraction, via modeling.
- Proficiency in Electromagnetic, Transmission-line & S-parameters theory and modeling.
- Understanding of signal integrity analysis parameters and evaluate trade-offs between
design parameters to determine an optimum solution space.
- Simulating and analyzing Power distribution network.
- Firmware knowledge and programming skills in Excel, PERL, Verilog and Matlab is
preferred.
- Experience using lab measurement tools such as oscilloscopes, TDR, VNA and software
tools such as Labview, PLTS.
- Strong written and oral communication in Chinese and English with customer service skills
4.
Sr. Verification Engineer –Shanghai
Duties will include working with a Verification Team to develop reusable block and system level verification environment using high level verification language to support ASIC development. Review RTL architectural and implementation specifications. Develop test plan, create stimulus drivers, monitors, reference models, scoreboards, protocol checkers to verify function and performance of advanced multiprotocol networking ASICs. Define and develop application tests required to verify ASICs meet functional and performance goals. Define and implement functional coverage plans. Define and implement code coverage plans. Develop testing and regression methodologies for new verification flow. Coordinate test plan implementation and regressions with remote team. Incorporate reusability into all aspects of the verification environment. Develop/maintain/enhance environment tools/scripts/makefiles. LSI Corporation is a leading provider of innovative silicon, systems and software technologies that enable products which seamlessly bring people, information and digital content together. We offer a broad portfolio of capabilities and services including custom and standard product ICs, adapters, systems and software that are trusted by the world's best known brands to power leading solutions in the storage and networking markets. We value the diversity of our people. LSI is an Equal Opportunity Employer.
Functional/Industry Knowledge:
Required: - ASIC Design and Verification skills and experience - Knowledge of high level verification languages such as SystemVerilog - Knowledge of data and telecommunication networking - Scripting skills, such as Shell, Perl and TCL - Good written and verbal communication skills Education/Certifications: Required Degree: MS Preferred Major: Electrical Engineering or related discipline
5.
Preamp Verification Engineer -Shanghai
Job Description
LSI Corporation is known worldwide as a storage market leader. Our silicon-to-systems solutions empower disk drives with the intelligence, flexibility, speed and reliability needed for high-capacity storage across every market segment, from portable consumer electronics devices to personal computers to enterprise-class storage systems and networks. LSI's Storage Peripherals Division is seeking an experienced verification design engineer to join the pre-amplifier design team. Preamp design team members define, create, modify and verify high-speed custom integrated circuits for hard disk drive (HDD) and tape recording products using leading edge CMOS and BiCMOS technologies
- Work with a Preamp Development team to create verilog testbench components and simulation environment.
- Create product test plans, test cases and perform simulation and debug of Storage Preamp mixed-signal devices.
- Must be experienced with Verilog and Verilog AMS and knowledgeable with functional coverage methodologies.
- Ability to follow a disciplined verification methodology and work closely with a multi-location, international design team.
- Excellent teamwork and communication skills are required.
- Preferred degree in Electrical or Electronic Engineering.
- BS required, MS or Ph.D. preferred
- The ideal candidate will have 5 years of experience as a member of a Design Verification team
- Experience with successful tapeout of SoC products from verification plan to sign-off including verification plan, reusable test bench development, random-constrained test case creation, RTL/Gate level simulation/debug, code/functional coverage analysis and regression
- Conversant with Verilog, SystemVerilog, Specman, Perl/Python/Tcl scripts, Makefile and EDA tools
- Experience with Assertion or Formal Verification a plus
- Strong communication skills (must be proficient in both spoken and written English)
- Able to travel internationally (to United States and throughout Asia
- Understanding of silicon process technologies (CMOS and Bipolar) and device physics would be a plus.
- Conversant with Verilog-AMS/Verilog-A and Analog Behavior Modeling would be a plus
- Proven analytical skills (application of math and physics to solve problems)
6.
Unix & CAD Tools Administrator
Job Description
In this position, you will be working in IT department in an international corporate as a Unix system administrator and EDA tools support expert. The ideal candidate needs to follow IC design customers work, familiar with the simulation jobs feature, trouble shoot the problems from Cad Tools and ICDS environment. Candidates must have a deep understanding of EDA tools and applications, be clear on the flow of IC design work and the requirement for IT engineering infrustructure in each phase. As a Unix administrator, you will handle day to day support on enterprise NIS/LDAP environment, managing compute farms of ~100 Linux servers, support NFS/CIFS applications on NAS/SAN storage, perform backup and restore activities. You will also work with global team to support both China and other sites, deploying global standards to China. You are expected to work as a bridge between IC design customers and IT support team
- +3 years experience of UNIX and Linux systems administration, strong experience in managing +100 servers with OS provisioning, system patching/upgrade, firmware upgrade etc.
- Familiar with NIS/LDAP mixed enterprise environment, NFS/CIFS setup and trouble shooting.
- Understand enterprise NAS/SAN storage architecture and configuration, experience on Netapp/EMC NAS/SAN storage will be an advantage. Hands-on experience on Veritas Netbackup.
- Demonstrable scripting/programming and debugging skills in at least perl and Unix shells.
- Experience on LSF or other grid computing systems will be a plus.
- Strong knowledge and deep understanding of IC design flow and tools (Candence, Mentor, Sysnopsys etc). Hands-on experience with more than one area of mixed-signal design (schematic capture, analog or mixed-signal simulation, custom layout, OVM verification) is highly desired.
- Experience with IC design and simulation tools such as Cadence ADE, Virtuoso, Spectre, AMS, Ultrasim, NCSim.
- Experience on Flex License Management.
- Proven Team work and customer oriented. effective communication skills to support local/internal customers and to setup effective working relationships within a global IT organization.
- Fluent in written and oral English
- Bachelor or Master degree in Electronics or Computer Science is preferred.
发表于 2011-12-20 09:09:30 | 显示全部楼层
这家公司一直在招人,是打广告还是真招人?
GMT+8, 2025-12-23 10:33 , Processed in 0.024671 second(s), 7 queries , Gzip On, Redis On.
