查看: 4280|回复: 7
[招聘] 【上海】知名美资IC公司诚聘Layout工程师
发表于 2011-12-6 14:34:40 | 显示全部楼层 |阅读模式
具体JD如下,感兴趣的请发简历至momo.zhang@bestgearconsulting.com
Layout Designer
•     Work effectively with designers to understand key layout constraints
•     Floor planning and layout of custom analog cells
•     Run Assura DRC, LVS, RCX at block and chip levels
•     Hold layout reviews of completed cells
•     Solid understanding and experience of 180nm, 130nm, 90nm, and deep sub-micron processes, IC layout methodology/techniques
•     Strong experience in CMOS/BCD process and custom analog layout
•     Experience with Cadence layout and physical verification flow (Assura)
•     2-5 years of layout experience
•     Understanding of layout considerations pertaining to matching, noise shielding, and latchup in analog, mixed signal and digital circuit
•     Experience in performing DRC, LVS, RCX, LVL, and other complex checks needed for tapeouts
•     Handling of large place and routed blocks and integrating it with the analog blocks is a plus
•     knowledge on putting large complex mixed-signal chips together a plus
•     Excellent communication and interpersonal skills.
•     Experience with analog mixed signal circuits
 楼主| 发表于 2011-12-8 16:20:29 | 显示全部楼层
每日更新
发表于 2011-12-8 20:19:06 | 显示全部楼层
哪个公司啊
 楼主| 发表于 2011-12-12 14:53:18 | 显示全部楼层
美资公司,做mobile power solution,感兴趣的话可邮件联系
 楼主| 发表于 2011-12-13 17:45:46 | 显示全部楼层
周二更新
发表于 2011-12-16 09:22:19 | 显示全部楼层
猎头发的吧?
 楼主| 发表于 2011-12-16 17:19:53 | 显示全部楼层
回复 6# mahaluluxu
    是的
 楼主| 发表于 2011-12-26 11:59:13 | 显示全部楼层
周一更新
GMT+8, 2025-12-21 05:41 , Processed in 0.024486 second(s), 8 queries , Gzip On, Redis On.
