楼主: lsqswl
[原创] cadence IUS9.2 ncverilog安装方法,环境设置,原创。
发表于 2014-7-12 08:58:21 | 显示全部楼层
回复 7# lsqswl
   换句话说跑混合电路仿真器spectreVerilog能工作吗,我装了incisive12.20只能跑verilog,混跑有license问题,能否指导一下?
发表于 2014-7-16 16:09:28 | 显示全部楼层
请问:LINUX RED HAT 6.3装上能用吗?
发表于 2014-7-17 14:45:42 | 显示全部楼层
学习了
发表于 2014-7-17 16:00:36 | 显示全部楼层
谢谢了,,就是有点多
发表于 2014-7-17 17:05:35 | 显示全部楼层
谢谢了绑定
发表于 2014-7-21 12:37:57 | 显示全部楼层
回复 8# liujian_2009
    Does this patch works for Incisive 12.2
发表于 2014-7-21 21:27:28 | 显示全部楼层
没用过这个软件!!
发表于 2014-7-22 00:45:29 | 显示全部楼层
回复 2# solarwafer
    too long
发表于 2014-7-26 19:18:08 | 显示全部楼层
Trying to check out license...
Incisive_HDL_Simulator 9.2 - Failed
NC_Verilog_Simulator 9.2 - Failed
Affirma_NC_Simulator 9.2 - Failed
Incisive_Verif_Engine 9.2 - Failed
Incisive_Design_Team_Simulator 9.2 - Failed
Incisive_Enterprise_Simulator 9.2 - Failed
ncsim: *F,NOLICN: Unable to checkout license for the simulation. (flag - 2) 'lic_error -9'.
openrisc@openrisc-VirtualBox:~/a$ lic_error -9
ERROR (LM -9): time difference between client and server is > 60 days
The system date on the client does not agree closely enough with the date
on the license server.  The difference can be no greater than 60 days
有人遇到过没?怎么解决?
发表于 2014-7-27 08:04:01 | 显示全部楼层
lab: *W,MISSYST (./a.v,21|12): Unrecognized system task or function (did not match built-in or user-defined names) [2.7.4(IEEE Std 1364-2001)].
If item was defined in a shared-object library, the problem could be:
libvpi.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS32 library.
libpli.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS32 library..
$fsdbDumpvars;
ncelab: *W,MISSYST (./a.v,22|12): Unrecognized system task or function (did not match built-in or user-defined names) [2.7.4(IEEE Std 1364-2001)].
Building instance overlay tables: .................... Done
Loading native compiled code:     .................... Done
Building instance specific data structures.
Design hierarchy summar
看了
http://bbs.eetop.cn/thread-359579-1-1.html
也没有解决
GMT+8, 2025-11-7 03:47 , Processed in 0.025791 second(s), 5 queries , Gzip On, Redis On.
