楼主: yuzhicai
[资料] Bipolar and MOS Analog Integrated Circuit Design
发表于 2015-4-28 14:46:24 | 显示全部楼层
The  LM386  is  a  power  amplifier  designed  for  use  in  low  voltage  consumer  applications.  The  gain  is
internally set to 20 to keep external part count low, but the addition of an external resistor and capasitor
between pins 1 and 8 will increase the gain to any value up to 200.
发表于 2015-4-28 15:13:02 | 显示全部楼层
虽是扫描的,但可接受
发表于 2017-10-11 16:51:12 | 显示全部楼层
找了好久了,谢谢楼主
发表于 2018-7-7 08:53:18 | 显示全部楼层
good material
发表于 2018-8-3 12:06:13 | 显示全部楼层
good matrial
发表于 2018-8-26 11:17:30 | 显示全部楼层
压缩包坏了??
发表于 2018-9-2 16:35:36 | 显示全部楼层
thanks
发表于 2018-9-7 10:26:31 | 显示全部楼层
回复 1# yuzhicai
   thanks
发表于 2018-9-7 11:36:49 | 显示全部楼层
Thanks a lot
发表于 2018-9-7 14:37:00 | 显示全部楼层
谢谢分享
GMT+8, 2025-9-15 05:39 , Processed in 0.016581 second(s), 3 queries , Gzip On, Redis On.
