查看: 24860|回复: 18
[解决] IC6141爆发了 问题已经解决
发表于 2011-10-25 20:52:56 | 显示全部楼层 |阅读模式
解决:
1.安装 pycell studio时候注意OA的版本要与Cadence的OA版本一致。
2.若一不能解决,则重新编译一下pycell库文件。请参考http://www.eda.ncsu.edu/wiki/FreePDK45:Using_P-Cells
发表于 2011-10-26 10:55:00 | 显示全部楼层
把log贴出来啊
发表于 2011-10-26 12:31:43 | 显示全部楼层
哇,找到cadence 的bug了。。
 楼主| 发表于 2011-10-26 23:54:26 | 显示全部楼层
回复 2# leefuture50
\# Program start time UTC 2011.10.25 14:18:44.337
\# Local time Tuesday 25 October 2011, 10:18 pm
\o Program:
@(#)$CDS: virtuoso version 6.1.4 11/17/2009 21:10 (sjfnl007) $
\o Hierarchy:
/eda/IC6141/tools.lnx86/dfII/
\o Sub version:
sub-version  IC6.1.4.485  (32-bit addresses)
\# Host name (type):
cat (i686)
\# Operating system:
Linux 2.6.18-164.el5 #1 SMP Tue Aug 18 15:51:54 EDT 2009
\# X display name (WxH):
:0.0 (1366x768)
\# Available geometry:
TL(0:25) BR(1365:742)
\# X server:
The X.Org Foundation
\# Depth of Visual (Root):
24 (24)
\# Number of Planes Used:
24
\# X version:
11.0 (vendor release 70101000)
\# X resource pool:
base 0x1600000, mask 0xfffff (1048575), shift 0
current id 0x3a, current max 0xffffa (1048570)
\# Memory report:
maximum data size 4294967295 (0xffffffff) bytes
\# Memory report:
maximum process size 4294967295 (0xffffffff) bytes
\# Initial sbrk value:
337494016 (0x141dc000) bytes
\# Maximum memory size:
4006551551 (0xeecf1fff) bytes
\# Initial memory used:
49078272 (0x2ece000) bytes
\# Qt version:
4.4.1
\# Window Manager:
gnome (metacity)
\# User Name:
XXXX
\o Working Directory:
cat:/home/XXXX/project/cds
\# Process Id:
8715
\o
\o COPYRIGHT ?1992-2009  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
\o           ?1992-2009  UNIX SYSTEMS Laboratories INC.,
\o                          Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o           RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\o Loading geView.cxt
\o Loading menuBuilder.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading LVS.cxt
\o Loading layerProc.cxt
\o Loading xlUI.cxt
\o Loading auCore.cxt
\o Loading vhdl.cxt
\o Loading seismic.cxt
\o Loading ci.cxt
\o Loading ams.cxt
\o Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.02s.
\o END OF SITE CUSTOMIZATION
\o Loading ./.cdsinit init file from the site init file.
\o //
\o //  Calibre Skill Interface * (v2011.3_18.12) *
\o //
\o //                 Copyright Mentor Graphics Corporation 2005
\o //                             All Rights Reserved.
\o //         THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
\o //            WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
\o //              OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
\o //
\o //
\o loading vars from /home/XXXX/45nm/FreePDK45/ncsu_basekit/cdssetup/cdsenv for tool layout
\o ---------------------------------------------------------------------------
\o Welcome to the FreePDK 45nm Free, Open-Source Process Design Kit
\o
\o This initiative is brought to you by the Semiconductor Research
\o Corporation (SRC), the National Science Foundation (NSF), Silicon
\o Integration Initiative (Si2), Mentor Graphics, and Synopsys.
\o
\o This version of the kit was created by Rhett Davis, Paul Franzon,
\o Michael Bucher, Sunil Basavarajaiah, and Harun Demircioglu
\o of North Carolina State University, and James Stine and Ivan Castellanos
\o of Oklahoma State University.
\o
\o Contributions and modifications to this kit are welcomed and encouraged.
\o
\o Copyright 2007 - W. Rhett Davis, Paul Franzon, Michael Bucher,
\o                  and Sunil Basavarajaiah, North Carolina State University
\o Copyright 2008 - W. Rhett Davis, Michael Bucher, and Sunil Basavarajaiah,
\o                  North Carolina State University (ncsu_basekit subtree)
\o                  James Stine, and Ivan Castellanos,
\o                  and Oklahoma State University (osu_soc subtree)
\o Copyright 2011 - W. Rhett Davis, and Harun Demircioglu,
\o
\o Licensed under the Apache License, Version 2.0 (the "License");
\o you may not use this file except in compliance with the License.
\o You may obtain a copy of the License at
\o
\o     http://www.apache.org/licenses/LICENSE-2.0
\o
\o Unless required by applicable law or agreed to in writing, software
\o distributed under the License is distributed on an "AS IS" BASIS,
\o WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
\o See the License for the specific language governing permissions and
\o limitations under the License.
\o
\o Done loading FreePDK customizations.
\i ddsWhatsNew()
\p >
\o Loading rte.cxt
\a hiResizeWindow(window(2) list(387:97 978:598))
\r t
\a hiResizeWindow(window(2) list(387:97 978:617))
\r t
\a hiResizeWindow(window(2) list(387:97 978:639))
\r t
\a hiResizeWindow(window(2) list(387:97 978:662))
\r t
\a hiResizeWindow(window(2) list(387:97 978:668))
\r t
\a hiResizeWindow(window(2) list(387:97 978:673))
\r t
\a hiResizeWindow(window(2) list(387:97 978:681))
\r t
\a hiResizeWindow(window(2) list(387:97 978:694))
\r t
\a hiResizeWindow(window(2) list(387:97 978:699))
\r t
\a hiResizeWindow(window(2) list(387:97 978:700))
\r t
\a hiResizeWindow(window(2) list(387:97 978:703))
\r t
\a hiResizeWindow(window(2) list(387:97 978:704))
\r t
\a hiResizeWindow(window(2) list(387:97 978:705))
\r t
\a hiResizeWindow(window(2) list(387:97 978:706))
\r t
\a hiCloseWindow(window(2))
\r t
\i ddsServOpen("study" "inv" "layout" "read" nil)
\o Loading le.cxt
\w *WARNING* (DB-270000): dbOpenCellViewByType: File '/home/XXXX/project/cds/lib/study/inv/layout/layout.oa' does not exist, or is not a valid OpenAccess database.
\a hiResizeWindow(window(1) list(316:47 1041:260))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:269))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:280))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:284))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:288))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:292))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:293))
\r t
\w *WARNING* (DEBASE-102084): Data trigger for viewType maskLayout failed.
\i ddsServOpen("NCSU_TechLib_FreePDK45" "nmos_vtg" "layout" "read" nil)
\w *WARNING* (DB-220704): The Pcell super master: NCSU_TechLib_FreePDK45/nmos_vtg/layout is not a SKILL super master.
\w                        The usage of non-SKILL Pcells in Virtuoso is not a supported feature.
\o Loading drdEdit.cxt
\o Loading leToolbox.cxt
\o Loading lo.cxt
\o Loading see.cxt
\o Loading treeAssistant.cxt
\o Loading asst.cxt
\o Loading oi.cxt
\o Loading vb.cxt
\o Loading techComp.cxt
\i ddsWhatsNew(nil 'Layout)
\o Loading vca.cxt
\# Memory report: now 98217984 (0x5dab000) bytes, UTC 2011.10.25 14:21:20.730
\a hiCloseWindow(window(6))
\r t
\a _hiSetCurrentWinNum(5)
\r t
\a hiResizeWindow(window(1) list(316:47 1041:307))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:318))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:343))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:371))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:394))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:411))
\r t
\a hiResizeWindow(window(1) list(316:50 1041:420))
\r t
\a hiResizeWindow(window(1) list(316:52 1041:425))
\r t
\a hiResizeWindow(window(1) list(316:51 1041:429))
\r t
\a hiResizeWindow(window(1) list(316:49 1041:431))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:431))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:433))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:435))
\r t
\a hiResizeWindow(window(1) list(316:49 1041:439))
\r t
\a hiResizeWindow(window(1) list(316:50 1041:442))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:442))
\r t
\a hiResizeWindow(window(1) list(316:47 1041:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1042:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1048:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1051:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1052:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1062:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1066:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1068:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1072:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1073:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1080:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1088:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1092:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1093:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1094:443))
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\a hiResizeWindow(window(1) list(316:47 1095:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1096:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1101:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1110:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1122:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1139:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1142:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1147:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1151:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1185:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1214:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1215:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1219:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1224:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1229:443))
\r t
\a hiResizeWindow(window(1) list(316:47 1243:443))
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\a hiResizeWindow(window(1) list(316:47 1244:443))
\r t
\r t
\a hiResizeWindow(window(1) list(316:47 1242:443))
\r t
\a mouseSingleSelectPt()
\i 0.02:0.18
\r nil
\i 0.1075:0.1925
\r nil
\a hiGetCurrentWindow()->stopLevel = 20
\w *WARNING* (DB-220704): The Pcell super master: NCSU_TechLib_FreePDK45/dcont/layout is not a SKILL super master.
\r 20
\a hiZoomAbsoluteScale(hiGetCurrentWindow() 0.9)
\r t
\r t
\r t
\r t
\a hiCloseWindow(swindow(3))
\r t
\i ddsServOpen("NCSU_TechLib_FreePDK45" "nmos_vth" "layout" "read" nil)
\w *WARNING* (DB-220704): The Pcell super master: NCSU_TechLib_FreePDK45/nmos_vth/layout is not a SKILL super master.
\i 0.1125:0.175
\r nil
\r 20
\a hiCloseWindow(swindow(4))
\r t
\i ddsServOpen("study" "zpcellSCRATCHXjzoi2173212" "layout" "read" nil)
\w *WARNING* (DB-270000): dbOpenCellViewByType: File '/home/XXXX/project/cds/lib/study/zpcellSCRATCHXjzoi2173212/layout/layout.oa' does not exist, or is not a valid OpenAccess database.
\i ddsServOpen("study" "inv" "layout" "edit" nil)
\i 8.1575:5.225
\r nil
\a leHiCreateWire()
\w *WARNING* (LE-105014): The Create Wire command is only available in Layout Suite CE, XL or GXL Editing
\w mode. In Layout Suite L Editing mode, use the Create - Shape - Geometric Wire
\w command.
\o Loading layers.cxt
\p >
\a mouseAddPt()
\i -4.925:1.8425
\r t
\a mouseAddPt()
\i 7.895:1.39
\r t
\a mouseAddPt()
\i 8.045:-4.435
\r t
\a mouseAddPt()
\i 0.94:-5.3
\r t
\a mouseAddPt()
\i 0.715:-9.2475
\r t
\a mouseSubSelectPt()
\i 13.345:-9.21
\r nil
\a hiZoomIn()
\i 11.9175:-7.33
\p >
\a addPoint(hiGetCommandPoint())
\i 13.045:-9.9625
\r t
\r t
\a mouseAddPt()
\i 13.55:-9.25
\r t
\a mouseAddPt()
\i 13.55:-9.25
\r t
\a hiZoomIn()
\i 13.2675:-8.8
\p >
\i 13.8925:-9.63
\r t
\r t
\a hiZoomIn()
\i 13.35:-9.17
\p >
\i 13.815:-9.365
\r t
\r t
\a deletePoint()
\r t
\a mouseAddPt()
\i 13.5475:-9.25
\r t
\a mouseAddPt()
\i 13.5475:-9.25
\r t
\a mouseAddPt()
\i 13.5475:-9.2475
\r t
\a mouseAddPt()
\i 13.5475:-9.2475
\r t
\r t
\a cancelEnterFun()
\r t
\r nil
\a geSave()
\r t
\a hiCloseWindow(swindow(6))
\o Loading cph.cxt
\r t
\a hiCloseWindow(swindow(7))
\r t
\o
\o Library Manager deleting cell "study/zpcellSCRATCHXjzoi2173212".
\i ddDeleteLocal(ddGetObj("study" "zpcellSCRATCHXjzoi2173212" "" ""))
\o Deleted cell 'study/zpcellSCRATCHXjzoi2173212'.
\a hiCloseWindow(swindow(8))
\r t
\i 10.2525:-1.605
\r nil
\a leHiCreateInst()
\p >
\a ddsSyncWithForm(hiGetCurrentForm() 'browse 'libName 'cellName 'viewName)
\r t
\i ddsServSelect("study" "inv" "")
\p >
\a hiDBoxOK(dBox)
\r t
\i ddsServSelect("NCSU_TechLib_FreePDK45" "" "")
\i ddsServSelect("NCSU_Devices_FreePDK45" "" "")
\i ddsServSelect("NCSU_Devices_FreePDK45" "NMOS_VTG" "")
\i ddsServSelect("NCSU_Devices_FreePDK45" "NMOS_VTH" "")
\i ddsServSelect("NCSU_Devices_FreePDK45" "NMOS_VTL" "")
\i ddsServSelect("NCSU_Devices_FreePDK45" "PMOS_THKOX" "")
\i ddsServSelect("NCSU_Devices_FreePDK45" "PMOS_VTG" "")
\i ddsServSelect("NCSU_Devices_FreePDK45" "PMOS_VTH" "")
\i ddsServSelect("NCSU_Devices_FreePDK45" "PMOS_VTL" "")
\i ddsServSelect("NCSU_TechLib_FreePDK45" "pmos_vtg" "layout")
\w *WARNING* (DB-220704): The Pcell super master: NCSU_TechLib_FreePDK45/pmos_vtg/layout is not a SKILL super master.
\a leCreateInstForm->columns->value=2
\r 2
\a leCreateInstForm->columns->value=3
\r 3
\a leRotateCB()
\r 18.4725
\r 2
\a leCreateInstForm->columns->value=1
\r 1
\r 2
\r 1
\a hiiToggleEnterForm(leCreateInstForm)
\r t
\a hiZoomIn()
\i -4.1075:-0.8725
\p >
\i 2.4725:-1.2025
\r t
\r t
\a hiZoomIn()
\i 0.7425:0.56
\p >
\i -0.0475:-0.195
\r t
\r t
\a mouseAddPt()
\i 0.2525:0.25
\o INFO (DB-170018): (dbPanic) dumping stack
\o virtuoso:dbPanic+166()
\o libvirtuos_sh.so:voDoAbortFuncs+37()
\o libvirtuos_sh.so:voSigAbort+167()
\o :__kernel_sigreturn+0()
\o liboaDesign.so:_ZNK12OpenAccess_47oaBlock14getInstHeadersEv+79()
\o virtuoso:_Z17dbsCheckRecursionPN12OpenAccess_48oaDesignE+52()
\o virtuoso:_Z17dbsCheckRecursionPN12OpenAccess_48oaDesignE+119()
\o virtuoso:dbCheckInstRecursion+109()
\o virtuoso:_ZN15leCreateInstCmd4doneEccP13_hiEFunStruct+1106()
\o virtuoso:doneCB+76()
\o virtuoso:hiApplyEnterFunction+446()
\o virtuoso:_ZN15leCreateInstCmd8addPointEP13_hiEFunStruct+952()
\o virtuoso:addPointCB+31()
\o virtuoso:hiiStackAddPoint+1086()
\o virtuoso:hiiLineAddPointProc+242()
\o virtuoso:_Z8addPointP9_hiWindowP9vodbPoint+228()
\o virtuoso:_Z11hiiAddPointP9_hiWindowP10iltLispval+125()
\o libil_sh.so:iliVcodeEval2+21063()
\o libil_sh.so:ilxSkillEval2+216()
\o libil_sh.so:_ilTopLevelSet+373()
\o libil_sh.so:ilxTopLevelCmd+380()
\o libil_sh.so:ilTopLevelCmd+37()
\o virtuoso:hiiPassCmdToIL+196()
\o virtuoso:_Z10processCmdP14queueCmdStruct+219()
\o virtuoso:_Z22hiiProcessEnqueuedCmdsv+201()
\o virtuoso:hiiProcessEvent+426()
\o virtuoso:_ZN12cdsHiqtMotif13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+140()
\o libQtCore.so.4:_ZN16QCoreApplication13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+73()
\o virtuoso:hiiFillCIWInPortCB+550()
\o libil_sh.so:iliBGetc+107()
\o libil_sh.so:ilGetCharPort+122()
\o libil_sh.so:input+176()
\o libil_sh.so:ilyylook+208()
\o libil_sh.so:ilyylex+28()
\o libil_sh.so:ilyyparse+1428()
\o libil_sh.so:ilReadport+562()
\o libil_sh.so:iliTopLevel+876()
\o virtuoso:hiiSubEnterEventShell+677()
\o virtuoso:_Z23hiiEnterLineCircleShellP9_hiWindowP13_hiEFunStruct19hiEnterFunctionType+514()
\o virtuoso:hiEnterPoint+103()
\o virtuoso:leiHiCreateInst+311()
\o virtuoso:lefHiCreateInst+237()
\o libil_sh.so:iliVcodeEval2+21194()
\o virtuoso:hiiProcessEvent+622()
\o virtuoso:hiMainLoop+529()
\o virtuoso:_ZN3rde15startHiMainLoopEv+2694()
\o virtuoso:Tcl_Main+781()
\o virtuoso:_ZN17TclCommandAdaptor8mainLoopEiPPcPKcRKSt6vectorI9ctuStringSaIS5_EEPFvvE+591()
\o virtuoso:_Z11finaleEntryiPPcPKcbP16finaleAppHarness+3885()
\o virtuoso:_Z12rdeStartMainiPPc+61()
\o virtuoso:main+997()
\o INFO (DB-120006): System crashed, you can use dbOpenPanicCellView() to open saved cellViews.
\o virtuoso has encountered a fatal internal application error and will now exit.
\o A crash report file for this error can be found at: /tmp/crashReport_102511_2225_IC6.1.4.485_tianlj_cat.log
我已经把 Linux 32bit PyCell Studio也安装了。用pyros测试可以编辑pcell。但是IC6141却调用不了pcell
发表于 2011-11-16 18:32:12 | 显示全部楼层
这几天也在装IC614,这个建议十分有用!
发表于 2011-11-16 21:36:42 | 显示全部楼层
回复 1# leejean
    有个问题,为什么一定要用pycell,而不用skill based pcell呢?这不是给自己增加难度么?
发表于 2011-11-17 10:16:42 | 显示全部楼层
nice...
发表于 2011-12-12 18:40:11 | 显示全部楼层
顶了,我也在装
发表于 2012-3-10 02:41:47 | 显示全部楼层
6.13 buxing
发表于 2012-3-10 02:44:03 | 显示全部楼层
oa banben
GMT+8, 2025-9-21 05:39 , Processed in 0.023622 second(s), 5 queries , Gzip On, Redis On.
