查看: 3680|回复: 0
[原创] Realview mdk仿真的问题
发表于 2011-10-24 15:28:05 | 显示全部楼层 |阅读模式
.c文件
extern void strcopy(char *dststr,const char *srcstr);
int main()
        const char * srcstr="asdsghzs";
        char dststr[10];
        strcopy(dststr,srcstr);
           return 0;
.s文件stack_top EQU 0x30000000
                PRESERVE8
                AREA STRCOPY_CODE,CODE,READWRITE
                EXPORT strcopy
                EXPORT start
                IMPORT main
                ENTRY
start
                LDR R13,=stack_top
                B main
strcopy
                LDRB R2,[R1],#1
                STRB R2,[R0],#1
                CMP R2,#0
                BNE strcopy
                MOV PC,LR
                END
配置文件//*** <<<  Use Configuration !disalbe! Wizard in Context Menu >>>  ***
FUNC void Setup (void)
    // <o> Program Entry Point
    pc = start;
map 0x48000000, 0x60000000 read write
Setup();                             // Setup for Running
RO 0x30000000
RW 0x40000000
MDK编译错误求助
GMT+8, 2025-12-30 22:47 , Processed in 0.020130 second(s), 6 queries , Gzip On, Redis On.
