查看: 2351|回复: 0
[招聘] 上海美光半导体公司招聘版图工程师
发表于 2011-9-4 14:40:20 | 显示全部楼层 |阅读模式
Responsibilities:
  • Develops and prepares multi-dimensional layouts and detailed drawings of the semiconductor devices from schematics and related geometry provided by design engineering. Work may be completed through use of CAD or other computerized equipment.
  • Checks dimensions, writes specifications, and verifies completed drawings, artwork or digitized plots. May check design layouts and detailed drawings. The Engineer will also:
  • Follows broad instructions.
  • Contributes to technical projects with some guidance.
  • Solves problems of moderate complexity.
  • Applies judgment in interpreting results and conducting quantitative analysis.
  • Integrates thorough technical knowledge within discipline.
  • Interacts with more experienced team members and managers to resolve complex problems.
  • Applies knowledge of a single OR multiple sub-function(s).
  • May lead or train others on the team.
   Job Requirements:
  • Bachelor’s Degree in Engineering (Microelectronics, Electronics)
  • At least 3 years relevant experience
  • Custom layout and successful tape-in experience is a must; flash layout experience is a plus
  • Proficiency in layout Electronic Data Automation (EDA) tools such as Virtuoso, Hercules, Calibre in doing layout edit and Lay-out Versus Vchematic (LVS), Design Route Check设计路线核对 (DRC), Electric Static Discharge (ESD) and NAC
  • Can work highly independently.
  • Experience in leading a small team is a plus.
  • Good teamwork and communication skills.
联系人:Carina Wang, 简历投递邮箱:carina.wang@alexmann.com.cn
GMT+8, 2025-12-20 17:42 , Processed in 1.122365 second(s), 6 queries , Gzip On, Redis On.
