查看: 6509|回复: 16
ams仿真,ic5141usr3+ius8.2+centos5.6,已经解决了!
发表于 2011-9-2 16:53:40 | 显示全部楼层 |阅读模式
Compilation successful.
ncelab: 08.20-p001: (c) Copyright 1995-2008 Cadence Design Systems, Inc.
Elaborating the design hierarchy:
ncelab: *N,SFEDPL: Deploying new SFE in analog engine.
ncelab: *F,INTERR: INTERNAL ERROR
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
  TOOL: ncelab 08.20-p001
  HOSTNAME: sim203
  OPERATING SYSTEM: Linux 2.6.18-238.el5xen #1 SMP Thu Jan 13 16:41:45 EST 2011 x86_64
  MESSAGE: Failed to open Spectre Simulation Image Generation library with error: /opt/ic5141usr3/tools/lib/libgcc_s.so.1: version `GCC_4.2.0' not found (required by /usr/lib/libstdc++.so.6)
ncelab: Memory Usage - 18.7M program + 14.3M data = 33.0M total
ncelab: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.2s, 1.8% cpu)
Failed to elaborate ("temp" "temp_ams1" "config").
Goole了一下,也有类似问题,但是没有找到解决办法,大家帮忙!!!
Note:我安装的是Base_IUS08.20.001_lnx86,patch过了!没有提示feature missing,但是有这个问题!
搞定了
之前只安装base,有没有patch都有问题!
上午重新安装base,然后update,仿真,没有上述error,只是lic checkout fail,然后patch,ok了!
 楼主| 发表于 2011-9-5 08:54:13 | 显示全部楼层
我安装的是ius8.2 base
 楼主| 发表于 2011-9-5 13:28:03 | 显示全部楼层
搞定了
发表于 2011-12-10 16:45:06 | 显示全部楼层
usr就是升级包的意思吗?base是必须装的,usr未必一定要装吧!!!
发表于 2012-3-9 13:47:30 | 显示全部楼层
感謝分享經驗
发表于 2013-10-1 15:36:28 | 显示全部楼层
楼主可否分享下软件啊
现在想安装ius
谢谢
发表于 2014-1-6 11:02:54 | 显示全部楼层
感谢分享!!!
发表于 2014-10-15 17:33:51 | 显示全部楼层
求ius8.2啊!楼主!
发表于 2014-10-17 13:29:02 | 显示全部楼层
所以到底是怎麼解決的阿
发表于 2015-1-11 13:08:19 | 显示全部楼层
谢谢楼主分享
GMT+8, 2025-11-1 03:08 , Processed in 0.028092 second(s), 5 queries , Gzip On, Redis On.
