查看: 5265|回复: 2
请问GT pattern density is 15%怎么解决?
发表于 2011-9-2 11:05:31 | 显示全部楼层 |阅读模式
我在IC5141下,用SMIC13工艺画版图,用Calibre进行DRC检查,老是说我GT pattern density is 15%,是不是说我的GT poly的密度不到15%?但是怎么修改设计才能符合要求呢?请高手指教,谢谢!
发表于 2011-9-6 10:00:49 | 显示全部楼层
You do not have to worry about it. The error is "poly density is < 15%", which will be solved at the end, when you make the mask, either Foundry or your Tape-out team will do the dummy-fill to ensure poly density will meet the need.
All you need to fix is "maximum density violation".
回复 支持 2 反对 0
 楼主| 发表于 2011-9-9 20:10:42 | 显示全部楼层
Thanks!
GMT+8, 2025-12-26 09:47 , Processed in 0.026768 second(s), 5 queries , Gzip On, Redis On.
