查看: 2569|回复: 4
[招聘] AMD内部职位推荐(上海)
发表于 2011-8-10 15:05:58 | 显示全部楼层 |阅读模式
内部推荐,有意者请发简历到wisewater@163.com
Title: Senior Design VerificationEngineer for Image Signal Processor
Role and Chance
l Understand functionalities of design in architecture and design specifications. Write the functional validation part of test plan from block level to    SoC level to achievethe functional coverage requirements.
l Deliver bug-free C-model from algorithm level to cycle level.
l Be responsible for test case composition, testbench and test environment setup,test automation tool development, BFM model coding and debugging.
l Support testing for DFP, DFT and FPGA
l Apply necessary verification methodologies to ASIC design, such as coverage, assertion,randomization, gatesim etc and achieve the verification goals
l Support FW/SW bring-up and debugging
l Working as the technical point of contact on the ASIC area.
Responsibilities:
1. Major in CS or EE and have Master degree or higher
2. 3 years beyond working experience on ASIC designverification
3. Must have strong background on image processing algorithms
4. Must be proficient in C++ programming and debugging inLinux and Windows platforms. Know well about SW engineering.
5. Must be experienced in various verification methodologies from block level to SoC level, and familiar with corresponding tools.
8. Must be skillful in shell/perl/tcl/Makefile programmingin linux OS.
9. Should have adequate ASIC design knowledge and be able todebug RTL codes using corresponding tools
10. Good English hearing, speaking, reading and writingcapabilities.
11. Will be a big plus if having tape-out experience.
发表于 2011-8-10 21:36:10 | 显示全部楼层
您好!有没有其他硬件的职位呢?
发表于 2011-8-10 21:37:23 | 显示全部楼层
您好!有没有其他硬件的职位呢?
发表于 2011-8-10 22:24:04 | 显示全部楼层
记号!!!
 楼主| 发表于 2011-8-11 16:57:12 | 显示全部楼层
回复 3# tiandan1986
    你好,我们部门目前比较缺Design verification。
GMT+8, 2025-12-18 12:13 , Processed in 0.018365 second(s), 7 queries , Gzip On, Redis On.
