查看: 2861|回复: 2
[招聘] 8月最新IC招聘职位!上海、北京
发表于 2011-8-4 14:36:01 | 显示全部楼层 |阅读模式
KT咨询以下职位的联系方式:analog1@kthr.comdigital1@kthr.com;software2@kthr.commanufacture@kthr.comfae@kthr.comasic1@kthr.comsales@kthr.com
欢迎筒子们联系哦
1.急招Asian Technical ASIC leader(上海)
岗位描述:
Responsibilities - To build designing team in Asia. The number of this team is 30-50 engineers on the 3rd year supporting 100M business in Asia - To provide direct technical customer support and build strong customer relationships - To work with the sales team for our business in Asia - To communicate with different designing team worldwide
职位要求:
Technical Qualification (15+ years)
• Has an excellent grasp of the backend ASIC methodology and flow from RTL to Tapeout in either prior technical contribution roles or technical management or lead roles. This covers o Third-party IP selection and integration o IO ring and package (flipchip, wirebond) co design o Analog IP selection and integration o High speed interface (DDR2/DDR3, Serdes) integration and analysis o Hierarchical physical implementation using a mainstream toolset such as Magma, Synopsys or Cadence o DFT implementation including at speed memory bist and repair and scan compression o IP test considerations such as high speed loop back tests and analog test inmtgeration o Timing closure and sign-off o Tapeout sign-off
• Any specialty and experience in ASIC methodology and flow will be highly desirable. Example(s): o Deep expertise with any mainstream ASIC tools or specialized tools along the flow o Low power flow with IPs and implementation techniques o Complex SOC implementation with flipchips and large number of on chip Serdes o Complex mixed signal chip integration with significant amount of on chip analog IPs o Special design and packaging such as MCMs and 3DICs
• Ability to contribute in a lead technical or advisory role to key R&D programs in improving or differentiating ASIC flow in power, performance area or cost.
• Experience with RTL design and verification and product design in any market segment in either technical or management role in a big plus
• Experience with Tapeout to full product production and rollout including proto bring-up and debug/validation process, characterization, qualification and supply chain management is high desirable. Management and Business Qualification
• Direct experience in ASIC technical project management is highly desirable
• Has strong leadership qualities that can support eSilicon GM of Asia to setup and grow a local ASIC technical team
• Experience in leading and managing global projects and internal engineering or product teams is highly desirable
• Experience in interfacing with third-party suppliers within the silicon supply chain (IP suppliers, design service firms, EDA suppliers, backend foundry, assembly and test operations) is a highly desirable
• Experience with key customer interfaces in ASIC support role or other partnering or supporting roles is highly desirable
• Well connected in business communities, including at VCs, across the Asian region is highly desirable
• Awareness of technical developments in the segments which are dominant across Asia so that we can better position ourselves when competing for business is highly desirable
• A strong technical leader who will be persuasive in selling our capabilities to high end Asian customers
• Has the ability to understand our limitations, but also able to work internally to mitigate the effect of those, so that they do not impede our ability to win business nor allow us to screw-up after winning deals. A strong team player who is flexible, dynamic and capable to partner with other functions as we are growing the Asian business aggressively
• Capable of putting together and giving presentations at high level shows so that we are perceived as a technical leader
2.诚招ECAD Engineer(上海)
岗位描述:
SUMMARY Be responsible to use established procedures to design printed circuit boards ESSENTIAL DUTIES AND RESPONSIBILITIES include the following. Other duties may be assigned. 
Work with manager and/or project manager to provide information that will aid in the initial quoting process. 
Provide Document Control with a complete design package consisting of data and documentation prior to production launch. Work concurrently with other Design Services departments, Business Unit Management, Manufacturing, Test, Purchasing, and Quality departments through the design phase of a program. Work to provide a design that not only meets the customer’s criteria, but is also of high quality, cost effective, and manufacturable. 
Support production discrepancies by incorporating fixes into subsequent revisions in a timely manner. 
Communicate and clarify engineering queries from PCB vendor. 
Record all ideas, sketches, and pertinent conversations in approved Design Log or Lab Notebook. 
Follow appropriate design process, work flow, checklists etc, to ensure quality deliverables. 
Stay abreast of the latest technology and techniques to provide designs that are competitive and cost effective. 
Exercises judgment within defined procedures and practices to determine appropriate action. 
Adhere to all safety and health rules and regulations associated with this position and as directed by supervisor. 
Comply and follow all procedures within the company security policy.
职位要求:
MINIMUM REQUIREMENTS 
Bachelor or above 
Min. 4 years PCB layout experiences 
Experienced on high speed PCB design and design for EMC 
Experienced on different PCB fabrication technology 
Experienced on different assembly process, know how it impacts the PCB design 
Wide range of product design experiences will be a plus 
Expert in cadence Allegro design tool, Min. 3 years Allegro design experiences is required LANGUAGE SKILLS Ability to read, analyze, and interpret general business periodicals, professional journals, technical procedures, or governmental regulations. Ability to write reports, business correspondence, and procedure manuals. Ability to effectively present information and respond to questions from groups of managers, clients, customers, and the general public. Fluent written and spoken English required. MATHEMATICAL SKILLS Ability to work with mathematical concepts such as probability and statistical inference, and fundamentals of plane and solid geometry and trigonometry. Ability to apply concepts such as fractions, percentages, ratios, and proportions to practical situations. REASONING ABILITY Ability to define problems, collect data, establish facts, and draw valid conclusions. Ability to interpret an extensive variety of technical instructions in mathematical or diagram form and deal with several abstract and concrete variables. PHYSICAL DEMANDS The physical demands described here are representative of those that must be met by a team member to successfully perform the essential functions of this job. Ability to work effectively under pressure with constantly changing priorities and deadlines. Individual may be required to sit, stand, walk regularly. Be accessible to production floor and office staff and to use required office equipment. Specific vision requirements include reading of written documents and use of computer monitor screen frequently. WORK ENVIRONMENT The work environment characteristics described here are representative of those an employee encounters while performing the essential functions of this job. Individual’s primary workstation is located in the office area, with some time spent each day on the manufacturing floor. The noise level in this environment ranges from low to moderate.
3.Senior Digital Design Verification Engineer(北京)
岗位描述:
Job Description Responsibility: The responsibilities include but not limited to:
1. Leading the high efficient verification platform development for application specific digital processor system and the whole chip digital system.
2. Leading the high efficient mixed signal verification platform development for mixed signal chips.
3. Work together with local and US team to define the verification strategy, test plan and quality benchmark.
4. Work together with local and US team for system validation.
5. Digital micro-architecture design, RTL design and implementation.
职位要求:
Requirement:
1. MSEE or PhD in EE or microelectronics or computer engineering.
2. 3 year+ experience for MSEE and 1 year+ for PHD on digital verification, RTL related design and implementation.
3. Proficient in SystemVerilog and advanced verification platform development (VMM/OVM/UVM/etc.).
4. Be familiar with SoC design and verification methodology is preferred.
5. Be familiar with digital signal processing for image processing or communication is preferred.
6. Good spoken and written English.
7. Self motivation, result oriented, good team work and communication skills.
4.Analog Design Engineer(上海)
岗位描述:
Responsibility: The primary role of this position is to design the highly complex analog and mixed-signal circuits. The responsibilities include but not to be limited to:
- Analog and mixed circuit definition, developing and evaluation.
- Design and development of the high performance analog circuits.
- Providing the technical guidance to layout, application and evaluation engineers.
- Engagement with key customers, application engineering and marketing is required to understand the key specifications and functions the designs must meet.
职位要求:
Requirement:
- MSEE/PHD in Microelectronics/Electrical Engineering/Communication Engineering
- Circuit design experience in mixed-signal, PLL, AMP, A/D, D/A converter designs.
- Proven track record of innovative initiatives in previous designs
- Self motivating, good team player and good communication skill
- Good English speaking and writing skill.
- Flexibility to have oversea and/or domestic travels.
5.Design Verification Engineer, Staff(上海)
岗位描述:
Job Function This DV Manager will be part of a team working on the future integration of complex SOC and switching product. The successful candidate will play a key role in driving many of the key DV architectural and in depth technical aspects of various projects and perform the following duties: - A multidisciplinary function, working in close collaboration with the design engineering teams and managers and directors on the various efforts involved in the definition and implementation of various projects and scoping development efforts and project schedules. - Responsible for the overall chip verification, in addition to the possibility of direct responsibility for the architecture of specific IP blocks or functions, depending on any specific area of expertise the candidate might have. - Interacting with and guiding a wide variety of internal and external design verification development teams, DV methodology, silicon IP and tool vendors. - Work with senior management, architects, and the design and DV teams across sites to contribute in definition of ASIC products specifications, feature definition and architecture.
职位要求:
Skills/Experience
- 10+ working experience in the field of design verification, experience in networking or switching design is a big plus.
- 3+ years as DV technical lead/architect or manager position.
- Proven experience of the latest design verification methodology such as OVM, assertion based coverage driven verification (code & functional coverage), constraint random test generation, formal checkings, power verification, modern design verification tools and languages (e.g. PSL/SVA, SystemC++, SystemVerilog, Vera, Specman, simulation systems)
- In depth experience in use of SystemVerilog and OVM to drive testbench is highly desirable
- In depth knowledge of ASIC design fundamentals from RTL to GDS including DFT verification.
- Experience in power verification is a plus.
- Proven debugging and problem analysis skills.
- Strong documentation and communication skills.
- Good people and project management skills including scheduling, resource allocation, risk assessment, matrix management, and process development and organized and methodical with proven ability to plan and execute project.
- Ability to work well in a dynamic, fast-paced, pressure filled, across multiple sites North America and Asia
- Flexible in terms of responsibilities and hours. Education Requirements MSEE or PHD in EE or CS
6.Lead Software Engineer(上海)
岗位描述:
SUMMARY Lead and manage a team of 5 to 12 software engineers. Work closely with the manager to build up, maintain and improve the competencies of the team. Educate and equip the team members with the proper process knowledge and technical skills. Work closely with TPM to provide the technical support for the project from the software perspective, including: quotation, resource arrangement, technologies, design and engineering. 。
Lead and manage a team of 5 to 12 software engineers. Work with manager to build up the team, maintain and improve the team competencies according to company’s business requirements. 
Get familiar with the Culture, business, policy and process, and fulfill the company policy and process in the team management and project activities. Feedback and improve the development process and management continuously.  Educate and equip the software engineers with the proper process knowledge and technical skills. Communicate with the team members to pass the company spirit and collect the feedback. 
Work with manager and/or technical project manager to provide information that will aid in the initial quoting process.  Stay abreast of the latest technology and techniques to provide competitive and cost effective designs. 
Assigned to a project and be responsible for the software design and development. 
Follow the direction of manager. 
职位要求:
MINIMUM REQUIREMENTS 
Has Bachelor or above degree with 6 years software development experience, including at least 3 years management experience. 
Be proficient in embedded software development process and methods; success experience in product development and team management. 
Software development experience required in at least one of these areas and preferably more than one: telecom, data-com, security, wireless, pc/server/storage, consumer electronics, automotive and medical 
Strong software programming background. Familiar with embedded software development under Windows and Linux. Experienced in at lease two of these operating systems: Embedded Linux, Android, Windows CE. 
Well understood the software development process and procedure. 
Good interpersonal and communication skills. 
Creative, self-motivated, responsible, good team work spirit. Work independently with minimum supervision. 
Familiar with FDA Medical device software – Software life cycle processes such as 510(k) submission etc. and good understanding of Clinical Information Systems as well as of PACS systems, HL7 and DICOM is a big plus. LANGUAGE SKILLS Has ability to read, analyze, and interpret general business periodicals, professional journals, technical procedures, or governmental regulations. Has ability to write reports, business correspondence, and procedure manuals. Has Ability to effectively present information and respond to questions from groups of managers, clients, customers, and the general public. Fluent written and spoken English required. MATHEMATICAL SKILLS Has ability to work with mathematical concepts such as probability and statistical inference, and fundamentals of plane and solid geometry and trigonometry. Has ability to apply concepts such as fractions, percentages, ratios, and proportions to practical situations. REASONING ABILITY Has ability to define problems, collect data, establish facts, and draw valid conclusions. Has ability to interpret an extensive variety of technical instructions in mathematical or diagram form and deal with several abstract and concrete variables. PHYSICAL DEMANDS The physical demands described here are representative of those that must be met by a team member to successfully perform the essential functions of this job. Has ability to work effectively under pressure with constantly changing priorities and deadlines. Individual may be required to sit, stand and walk regularly. Be accessible to production floor and office staff and to use required office equipment. Specific vision requirements include reading of written documents and use of computer monitor screen frequently. WORK ENVIRONMENT The work environment characteristics described here are representative of those an employee encounters while performing the essential functions of this job. Individual’s primary workstation is located in the office area, with some time spent each day on the manufacturing floor. The noise level in this environment ranges from low to moderate.
7.FAE_Global Accoutn(北京)
岗位描述:
Responsibility:
- Responsible for the technical introduction and promotion of XX products (ADC/DAC, Clock, Mixer, Mod/DeMod, Amplifiers, Power management, PLL, DDS, Power detector, etc.) to customers.
- Being first line of technical support for customers.
- Responsible for on site technical support/debugging/testing.
- Responsible for technical training, seminar, and knowledge delivering to customer, identify key issue and communication with product line.
- Responsible for designing XX products into customer's project, design-in tracking and follow up.
职位要求:
Requirement:
- MSEE/PHD, 3+ years of communication/RF/converter related experience
- Solid knowledge in wireless communications/converter/RF front end - experience in wired communication, digital signal processing and power design is a plus
- Skilled on lab equipments, testing and debugging
- Fluent in Mandarin and English
- Excellent interpersonal and communication skills
- Strong team player
- Continuously seeks to improve functional and professional skills and knowledge
8.FAE-Huawei(上海)
岗位描述:
Responsibility:
- Responsible for the technical introduction and promotion of new analog products (LNA, gain blocks, Mixer, Modulator/Demodulator, PLL, ADC/DAC, Amplifiers, clock, etc.) to customers.
- Give seminars to customers introducing existing and new XX core products.
- Being first line of technical support for customer and sales
- Responsible for defining and clarifying any technical issues related to new or existing products and communicating to product lines.
- Responsible for attending and absorbing information at XX FAE training, and communicating that back to the EC region.
职位要求:
Requirement:
- Master degree in Electronics Engineering, 2+ years experience in wireless communication in applications engineering or R&D
- Solid analog circuit and digital circuit basics. Thorough understanding in analog, digital and mixed signal processing technology
- Any of below expertise is preferred: Knowledge in RF Hardware system design High speed wireless communication system hardware design
9.Design Quality Manager(上海)
岗位描述:
Responsibility: 
Ensure Design organization fully compliance with regulations especially ISO9001/ISO13485/ISO16949/ISO14000 
Ensure appropriate training for all personnel in-line with ISO9001/ISO13485/ISO14000/IEC60601 and associated regulatory standards and requirements for related design project and activities 
Effective management of internal audit 
Ensure effective interactions/cooperation with quality teams worldwide effectively 
Interface/organize with regulatory agencies, customers and professional organizations for the successful audit  Investigate, audit, analyze, propose, realize the improvements in quality management 
Schedule, prepare, organize management review meetings 
Coordinate in activities relating to global quality 
Provide quality management assistance and leadership to all department in design organization 
Initiate, change and update product development process as applicable. 
Performs other job-related duties as assigned.
职位要求:
Requirements: 
Bachelor in electronic/mechanical technical/science area; an advanced degree is preferred 
More than 5 years in design quality management position(some years in design especially electronic medical device design is mandatory)with 5 or more years in a management position is also required. The experience on the mechanical-electronic product design is a plus 
Significant experience with quality systems in a Medical device environment is also required. 
Be able to communicating with auditor(customer/TUV/internal/etc.) successfully 
Have up-to-date knowledge of applicable regulations, guidelines and standards(especially IEC60601-1, ISO13485, ISO9001, ISO14000, ISO16949 and FDA), knowledge on IEC60601-1 and other standard is prefered 
Independent decision-making is expected for daily work 
Good communication skill to communicate with different function team 
Fluent English on communication with global team 
Profession with passion 
Integrity and commitment
10.Technical Program manager (focus on medical field)上海
岗位描述:
SUMMARY This is a position of manager, who will take the responsibility for the development the program of design project by working closely with the function mangers in design center and the sales and business guys in business to propose the technical solution and quotation. He is responsibility to win the design project and report to the director of design. ESSENTIAL DUTIES AND RESPONSIBILITIES include, but are not limited to the following: 
Lead the team to deliver the technical proposal 
Lead and be responsible for the quotation 
Communicate and work proactively with the customer to develop the program 
Work closely with sales and business to development the program 
Make sure the delivery is on time and meet the customer schedule 
Make sure the proposal and quotation is reasonable, competitive and executable
职位要求:
Person Background: 
Master or above in double E or hardware computing 
Have the electronic circuit design experience in different products 
Have the experience as the project/program manager 
Strong business sense and flexible 
Strong English in writing and speaking 
Strong mandarin in writing and speaking 
Strong presentation and communication skill 
Have software development knowledge in embed system, the development experience is a plus 
Have the mechanical design knowledge, the design experience is a plus 
Work experience in international company and have the capability in multi-culture environment Person Attributes: The successful candidate will be a self-motivated individual capable of working with a minimum of supervision in a dynamic team environment. Good interpersonal skills: be able to communicate i with members of other teams, departments and clients; as a high degree of liaison is needed.
11.Supply Chain Project Manager (SCPM)上海
岗位描述:
LEADERSHIP RESPONSIBILITIES Supply Chain Team Guidance: 
Provide supplier (market) as cost guidance on key components as commodities, via GCM , SCSM, during the PCP process after reviewing with lead SCPM. 
Identify competitive functional alternatives during the definition stages of the project. 
Work closely with Product Architecture or Project Manager to match The and customer road maps to supplier road maps based on lead SCPM direction. 
Scan for new suppliers and manage their initial selection. 
Coordinate with the purchasing community to structure the relation with our suppliers. 
Supporting lead SCPM on the overview and projects progress management of the unit. 
Following and execution strategies viable for the domain with reference to the Strategies. 
Adhere the rules 
Use all system tools in daily works effectively. 
Participate in process improvement and process development within the domain. SUPPLY CHAIN MANAGEMENT RESPONSIBILITIE Cost Management: 
Participating key negotiations for ASIC’s within assigned RFQ or assigned program including component price evolution.  Negotiate favorable pricing, payment terms, and advanced supply chain optimization programs such as supplier-owned inventory, Just-in-Time delivery schedules, reduced lead times and cancellation terms, return privileges, DIA and EDI/SIS demand communication with key suppliers falling outside the strategic supplier base.
职位要求:
TECHNICAL MANAGEMENT RESPONSIBILITIES Project Management 
Work in concert with Global Commodity Management on assigned programs, lead the effort to obtain full commodity and sourcing control of BOM and AVL in the design phase. 
Assist in executing the RFQ as appropriate for the program. 
Through understanding and experience in the basic processes of PCP support PM. 
Execute the Early Supplier Involvement program. 
Assuring the completeness and accuracy of the different databases with purchasing data and contributing to the underlying processes. (Transfer – Production sites) Customer Service and Business Development 
Become the supply chain expert as it relates to the particular market and strategy 
Anticipate and meet/exceed customer expectations by solving problems quickly and effectively. Make program and customer service issues the top priority. 
Represent the materials team in a professional manner during program meetings, audits, presentations and conference calls.
Comply and follow all procedures within the company security and ethics policies. MINIMUM REQUIREMENTS A Bachelor’s degree in Electrical Engineering is must. Other discipline’s will be considered with a proven track record in Medical appropriate market segment. Prefer minimum 5 years supply chain related experience at a major OEM in the Medical market segment; or an equivalent combination of education and experience. Experience in a design and product launch environment is important. An understanding of electronics manufacturing and materials management as well as a proven track record in negotiation, and cost reduction activities; Strong leadership skills. Domestic and international travel is required (up to 50%). LANGUAGE SKILLS Ability to read, analyze, interpret and communicate regarding common scientific and/or technical journals, financial reports, and legal documents. Ability to respond to common inquiries or complaints from customers, regulatory agencies, or members of the business community. Ability to effectively present information to Business Unit Management, Customer, and other members of the staff. Advanced PC skills, including training and knowledge of the software packages. ANALYTICAL SKILLS Ability to calculate figures and amounts such as discounts, interest, commissions, proportions, percentages, area, circumference, and volume. Ability to solve practical problems with limited information. Ability to interpret a variety of instructions furnished in written, oral, diagram, or schedule form. PHYSICAL DEMANDS The physical demands described here are representative of those that must be met by an employee to successfully perform the essential functions of this job. Ability to work effectively under pressure with constantly changing priorities and deadlines. Individual may be required to sit, stand, walk regularly and occasionally lift up to 15 lbs. Be accessible to production floor and office staff and to use required office equipment. Specific vision requirements include reading of written documents and use of computer monitor screen frequently. WORK ENVIRONMENT The work environment characteristics described here are representative of those a team member encounters while performing the essential functions of this job. Individual’s primary workstation is located in the office area, where the noise level is low. Team member may frequently be present on the manufacturing floor where the noise level is low to moderate.
12.VC development engineer(上海)
岗位描述:
总体描述:
负责VC代码编写及开发文档编写;
岗位职责:
根据计划表编写代码,按时、保质。编写开发文档,保证文档通用性。
服从项目经理及上级安排,认真做好每项交代工作。
协调配合好开发小组,保证项目顺利完工。
对自己编写代码测试,保证编码无误。
协助好测试小组对所编写代码进行测试。
职位要求:
要求:
(1)具有VC三年的开发经验;
(2)熟悉Socket编程;
(3)熟悉MFC基础类库;
(4)对VC的图形绘制、交互设计比较熟悉;
(5)熟悉XML;
(6)知名大学本科毕业。
13.JAVA Engineer(上海)
岗位描述:
工作任务:
-GPS通信服务器软件开发
-GIS软件开发岗位职责:
- 完成日常的工作任务
- 参与通信服务器的设计、升级、研发
- 参与需求调研,并提出有效的解决方案建议
- 参与GIS系统的设计、开发、维护过程
- 保证任务按质按量完成
- 善于主动发现问题,提出易用的合理化建议
- 协助进行团队技术管理上的更新,编写必要的工作任务文档
- 积极完成上级安排的工作任务
职位要求:
岗位要求:
- 计算机相关专业,大学本科以上学历
- 4年以上J2EE应用开发经验,2年以上大型项目总体设计、技术实施和项目管理经验
- 精通J2EE相关技术,如jsp、servlet、javascript、ajax、jdbc、xml
- 精通java多线程和Socket编程
- 精通Oracle等主流关系数据库管理系统,熟悉PL/SQL
- 熟悉struts、hibernate等流行开源中间件,熟悉tomcat、weblogic等应用服务器
以上职位来源于“胡说IC”
发表于 2011-8-4 23:35:24 | 显示全部楼层
好多啊
发表于 2011-8-5 09:02:58 | 显示全部楼层
very good!
GMT+8, 2025-12-27 13:13 , Processed in 0.017400 second(s), 6 queries , Gzip On, Redis On.
