楼主: rabbit_001
手把手教你如何安装PJ设置 CALIBRE 2010-图文并茂
发表于 2011-8-15 17:30:58 | 显示全部楼层
好东西下来看看
发表于 2011-8-15 19:27:46 | 显示全部楼层
这个工具是做什么用的啊,能否介绍一下?
发表于 2011-8-28 14:45:55 | 显示全部楼层
我系统是ubuntu10.04 照着做的,license始终启动不了,我电脑上面还有其他的软件破解 我把他们放在一起了,原来的还是可以用,但是这个不行,另外 打补丁也出现有一个error和一大堆worning,求解啊
启动license的报错:
13:51:23 (lmgrd) -----------------------------------------------
13:51:23 (lmgrd)   Please Note:
13:51:23 (lmgrd)
13:51:23 (lmgrd)   This log is intended for debug purposes only.
13:51:23 (lmgrd)   In order to capture accurate license
13:51:23 (lmgrd)   usage data into an organized repository,
13:51:23 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s
13:51:23 (lmgrd)   software license administration  solution,
13:51:23 (lmgrd)   FLEXnet Manager, to  readily gain visibility
13:51:23 (lmgrd)   into license usage data and to create
13:51:23 (lmgrd)   insightful reports on critical information like
13:51:23 (lmgrd)   license availability and usage. FLEXnet Manager
13:51:23 (lmgrd)   can be fully automated to run these reports on
13:51:23 (lmgrd)   schedule and can be used to track license
13:51:23 (lmgrd)   servers and usage across a heterogeneous
13:51:23 (lmgrd)   network of servers including Windows NT, Linux
13:51:23 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
13:51:23 (lmgrd)   www.acresso.com for more details on how to
13:51:23 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
13:51:23 (lmgrd)   for your enterprise.
13:51:23 (lmgrd)
13:51:23 (lmgrd)
13:51:23 (lmgrd)
13:51:23 (lmgrd) license manager: can't initialize:Cannot find license file.
13:51:23 (lmgrd) The license files (or license server system network addresses) attempted are
13:51:23 (lmgrd) listed below.  Use LM_LICENSE_FILE to use a different license file,
13:51:23 (lmgrd) or contact your software provider for a license file.
13:51:23 (lmgrd) Filename: "/usr/local/flexlm/licenses/license.dat"
13:51:23 (lmgrd) License Path: "/usr/local/flexlm/licenses/license.dat"
13:51:23 (lmgrd) FLEXnet Licensing error:-1,359
13:51:23 (lmgrd) System Error:2 No such file or directory
13:51:23 (lmgrd) For further information, refer to the FLEXnet Licensing documentation,available at ************
13:51:23 (lmgrd) Using license file "/usr/local/flexlm/licenses/license.dat"
patck报错:
warn : empty file: pkgs/mgc_doc_utils/olh_perl/_lib/i686-linux/auto/DB_File/DB_File.bs - skipping
89% .../pkgs/icv/examples/calibre_CFA_pkg/dfmdb/master/65.layer : warn : empty file: shared/pkgs/icv/examples/calibre_CFA_pkg/dfmdb/references/1.ref - skipping
warn : empty file: shared/pkgs/icv/examples/calibre_CFA_pkg/dfmdb/references/0.ref - skipping
warn : empty file: shared/pkgs/icv/examples/calibre_CFA_pkg/dfmdb/references/db.ref - skipping
94% bin/lmstaterror: failed to read+write: sfk - skipping
warn : empty file: tmp/.flexlm/lmgrdl.3294 - skipping
warn : empty file: tmp/.flexlm/lmgrdl.6806 - skipping
warn : empty file: tmp/.flexlm/lmgrdl.3223 - skipping
warn : empty file: tmp/.flexlm/lmgrdl.3188 - skipping
warn : empty file: tmp/.flexlm/lmgrdl.3028 - skipping
warn : empty file: tmp/.flexlm/lmgrdl.3164 - skipping
warn : empty file: tmp/.flexlm/lmgrdl.3315 - skipping
warn : empty file: tmp/.flexlm/lmgrdl.3213 - skipping
warn : empty file: tmp/.flexlm/lmgrdl.3220 - skipping
warn : empty file: tmp/.flexlm/lmgrdl.3320 - skipping
7188 files checked, 0 changed.
1 errors, 32 warnings occurred.
发表于 2011-8-30 14:32:28 | 显示全部楼层
Thanks
发表于 2011-9-7 12:34:22 | 显示全部楼层
下载看看,好资料!
发表于 2011-9-8 11:57:49 | 显示全部楼层
回复 1# rabbit_001
    帅哥··能把你里面用到的破解工具给我发一下哈!!!可以吗?
发表于 2011-9-12 09:59:15 | 显示全部楼层
下一个,顶一下!
发表于 2011-9-20 13:42:52 | 显示全部楼层
thanks!
发表于 2011-9-20 21:02:57 | 显示全部楼层
谢谢分享。
发表于 2011-10-23 01:21:23 | 显示全部楼层
下来看看
GMT+8, 2025-12-5 18:56 , Processed in 0.018552 second(s), 3 queries , Gzip On, Redis On.
