查看: 3680|回复: 9
[资料] The Frequency Spectrum of PulseWidth Modulated Signals
发表于 2011-7-28 12:40:35 | 显示全部楼层 |阅读模式
关键词:PWM频谱,自然采样,均匀采样,单边调制,双边调制
Abstract
The determination of the frequency spectrum of a pulse width modulated (PWM) signal
with general band-limited input x(t)has been an open problem for many years.We describe
a new approach that gives exact analytical expressions for the spectra of uniform-sampling
PWM signals and natural-sampling PWM signals with single-edge as well as with doubleedge
modulation. For the special case of single tone modulating signals, our results reduce
to those obtained previously using a double Fourier series method. We also show that if the
maximum magnitude of the derivative of x(t)is smaller than twice the carrier frequency,
then a PWM signal consists of a baseband signal y(t)together with y(t)phase-modulated
onto each carrier harmonic, where, for uniform-sampling PWM, y(t)is a nonlinear function
of the modulating signal x(t), while for natural-sampling PWM, is just x(t)itself, that
is, there is no distortion in the baseband when natural sampling is used.
 楼主| 发表于 2011-7-28 12:53:49 | 显示全部楼层
The frequency spectrum of pulse width Modulated signals.pdf (296.13 KB , 下载次数: 46 )
重传附件,刚才貌似没成功的嘛
发表于 2011-7-28 15:55:40 | 显示全部楼层
非常感谢
发表于 2011-7-28 23:41:53 | 显示全部楼层
顶一个下来看先
发表于 2011-7-31 10:13:04 | 显示全部楼层
谢谢共享
发表于 2011-8-4 06:01:56 | 显示全部楼层
Thanks
发表于 2011-9-1 22:25:03 | 显示全部楼层
非常需要这样的文章。
发表于 2013-8-12 10:22:17 | 显示全部楼层
dinging
发表于 2019-4-18 23:59:43 | 显示全部楼层
非常感谢!!!
发表于 2019-4-19 07:47:35 | 显示全部楼层
Good.
GMT+8, 2025-12-29 16:55 , Processed in 0.027463 second(s), 6 queries , Gzip On, Redis On.
