查看: 3979|回复: 8
[资料] 1394 标准
发表于 2011-7-23 17:46:30 | 显示全部楼层 |阅读模式
IEEE 1394 -1995
IEEE Standard for a High Performance
Serial Bus
1. Overview
1.1 Scope
This standard describes a high-speed, low-cost Serial Bus suitable for use as a peripheral bus or a backup to parallel
backplane buses. Highlights of the Serial Bus include
a) Automatic assignment of node addresses—no need for address switches.
b) Variable speed data transmission based on ISDN-compatible1 bit rates from 24.576 Mbit/s for TTL
backplanes to 49.152 Mbit/s for BTL backplanes to 98.304 Mbit/s, 196.608 Mbit/s, and 393.216 Mbit/s for
the cable medium.
c) The cable medium allows up to sixteen physical connections (cable hops), each up to 4.5 m, giving a total
cable distance of 72 m between any two devices. Bus management recognizes smaller configurations to
optimize performance.
d) Bus transactions that include both block and single quadlet reads and writes, as well as an “isochronous”
mode that provides a low-overhead guaranteed bandwidth service.
e) A physical layer supporting both cable media and backplane buses.
f) A fair bus access mechanism that guarantees all nodes equal access. The backplane environment adds a
priority mechanism, but one that ensures that nodes using the fair protocol are still guaranteed at least partial
access.
g) Consistent with ISO/IEC 13213 :1994 (IEEE Std 1212-1991).
 楼主| 发表于 2011-7-23 17:49:06 | 显示全部楼层
IEEE Std 1394a-2000
Serial Bus—Amendment 1
Contents
0. Introduction......................................................................................................................................... 1
0.1 Scope........................................................................................................................................... 1
0.2 Purpose........................................................................................................................................ 2
0.3 Document organization ................................................................................................................ 2
1. Overview............................................................................................................................................. 3
1.2 References................................................................................................................................... 3
1.5 Service model.............................................................................................................................. 4
1.6 Document notation....................................................................................................................... 5
2. Definitions and abbreviations ............................................................................................................ 11
2.1 Conformance............................................................................................................................. 11
2.2 Technical glossary...................................................................................................................... 11
3. Summary description ......................................................................................................................... 15
3.9 New features of IEEE Std 1394a-2000 ...................................................................................... 15
4. Cable PHY specification................................................................................................................... 24
4.2 Cable physical connection specification .................................................................................... 24
4.3 Cable PHY facilities................................................................................................................... 48
4.4 Cable physical layer operation................................................................................................... 62
5A. PHY/link interface specification........................................................................................................ 98
5B. PHY register map............................................................................................................................ 125
6. Link layer specification................................................................................................................... 133
6.1 Link layer services ................................................................................................................... 133
6.2 Link layer facilities .................................................................................................................. 134
6.3 Link layer operation ................................................................................................................. 142
7. Transaction layer specification ........................................................................................................ 143
7.1 Transaction layer services........................................................................................................ 143
7.3 Transaction operation............................................................................................................... 144
7.4 CSR Architecture transactions mapped to Serial Bus.............................................................. 153
8. Serial Bus management specification .............................................................................................. 154
8.2 Serial......
发表于 2011-7-26 16:19:42 | 显示全部楼层
非常感谢
发表于 2011-8-16 22:32:33 | 显示全部楼层
有1394B的协议么
发表于 2011-9-11 22:43:25 | 显示全部楼层
学习了!!!!
发表于 2011-12-7 17:14:44 | 显示全部楼层
没2008么?
发表于 2011-12-7 21:16:16 | 显示全部楼层
学习了!!!!
发表于 2014-12-12 20:10:31 | 显示全部楼层
zenme xiaz ai a
发表于 2016-9-25 07:38:08 | 显示全部楼层
学习了
GMT+8, 2025-12-29 10:06 , Processed in 0.023548 second(s), 5 queries , Gzip On, Redis On.
