发表于 2007-2-6 18:06:21
显示全部楼层
How to Stabilize a Loop
Almost any loop can be divided into two major portions. One is the power processing portion,
which takes a control signal as an input and outputs the variable to be controlled, which may be
voltage, current, torque, speed, position, temperature, etc. This portion is typically called the
modulator or plant. The other portion is the error amplifier, which compares a sample of the
controlled output to a reference, amplifies the difference, and outputs a control signal to the
modulator or plant. This portion is usually called the amplifier. Figure 3 shows the definition of
these two blocks in a typical switch-mode power supply. |
