查看: 3617|回复: 0
[原创] 链表应用
发表于 2011-7-7 16:35:14 | 显示全部楼层 |阅读模式
typedef struct STRUCTMENUINFO
unsigned int uTab;//号
char MenuName[64];//名字
float fDyj;//单价
float fNum;//数量
float fZdyj;//总价
struct STRUCTMENUINFO *Node;//节点存储
} stMenuInfo;
int PrintMenuInfoFun(stMenuInfo *pstRootNode,unsigned int uTab)
stMenuInfo *pstRootNodeTmp = 0ul;
if ((0ul == pstRootNode) || (0 == uTab))
  printf("Print Info Fun Null!");
  return ~(0);
pstRootNodeTmp = pstRootNode;
while(pstRootNodeTmp->Node != 0ul)
  pstRootNodeTmp = pstRootNodeTmp->Node;
  if (pstRootNodeTmp->uTab == uTab)
   printf("Name:%s\n", pstRootNodeTmp->MenuName);
   printf("dj:%f\n", pstRootNodeTmp->fDyj);
   printf("num:%f\n", pstRootNodeTmp->fNum);
   printf("zdj:%f\n", pstRootNodeTmp->fZdyj);
   printf("Tab:%d\n", pstRootNodeTmp->uTab);
return 0;
int PrintNameFun(stMenuInfo *pstRootNode,char *Name)
if ((0ul == pstRootNode) || (0ul == Name))
  return ~(0);
  if (!strncmp(pstRootNodeTmp->MenuName, Name))
return 0;
int AddMenuInfoFun(stMenuInfo *pstRootNode, unsigned int uTab, char *Name, float fNum, float fDyj)
stMenuInfo *pstNodeInfo = 0ul;
stMenuInfo *pstNewNode = 0ul;
if ((0ul == pstRootNode) || (0ul == Name) || (0 == uTab))
  printf("Fun Info Data to Null!");
  return ~(0);
if (pstRootNodeTmp->Node == 0ul)
  pstNewNode = (stMenuInfo *)malloc(sizeof(stMenuInfo));
  pstNewNode->Node = 0ul;
  pstNewNode->uTab = uTab;
  strcpy(pstNewNode->MenuName, Name);
  pstNewNode->fDyj = fDyj;
  pstNewNode->fNum = fNum;
  pstNewNode->fZdyj = (fDyj * fNum);
  pstRootNodeTmp->Node = pstNewNode;
return 0;
int DelMenuInfoFun(stMenuInfo *pstRootNode, unsigned int uTab)
stMenuInfo *pstNextRootNode = 0ul;
  return ~(0);
  pstNextRootNode = pstRootNodeTmp;
   pstNextRootNode->Node = pstRootNodeTmp->Node;
return 0;
int main()
stMenuInfo *RootNode = (stMenuInfo *)malloc(sizeof(stMenuInfo));
RootNode->Node = 0ul;
AddMenuInfoFun(RootNode, 2, "快问问", 3.0, 2.5);
AddMenuInfoFun(RootNode, 3, "快", 5, 2);
AddMenuInfoFun(RootNode, 2, "问", 3, 1);
AddMenuInfoFun(RootNode, 4, "课文", 1, 1.5);
AddMenuInfoFun(RootNode, 3, "英语", 7, 3);
PrintMenuInfoFun(RootNode, 2);
PrintNameFun(RootNode, "课文");
DelMenuInfoFun(RootNode, 2);
PrintMenuInfoFun(RootNode, 3);
while(1);
return 0;
GMT+8, 2025-10-27 03:20 , Processed in 0.019765 second(s), 5 queries , Gzip On, Redis On.
