查看: 3106|回复: 3
[原创] AD公司BF DSP 算法包 与大家共享
发表于 2006-10-31 14:57:34 | 显示全部楼层 |阅读模式
File Name:      dct_122700.zip
File Contents:  read_me.txt
                mds_def.h
                r8x8dct.asm
                tr8x8dct.c
                tr8x8dct.h
Module Name:    The implementation of forward DCT for 8x8 real data.
Label Name:     __r8x8dct
Description:    This is the implementation of Chen's algorithm of DCT.
                It is based on the separable nature of DCT for multi-
                dimension. The input matrix is 8x8 real data. First, one dime-
                sional 8-point DCT is calculated for each of the 8 rows. The
                output is stored in a separate matrix after transpose. Then again
                8-point DCT is calculated on each row of matrix. The output
                is again stored in a transpose matrix. This is final output.
                Chen's algorithm has 4 stages of implementation. In the first
                stage there are additions and subtractions only. In the second
                stage addition and subtraction is done with one multiplication.
                In the third and last (fourth) stages  more MAC operations are
                involved.
                This implementation works only for 8x8 input. The input data
                should be real. The range of input should be -256 to 255.
                The algorithm is in-placed.
                The prototype of the C callable is as follows:
                _r8x8dct(fract16 *in, fract16 *coeff, fract16 *temp);
                *in -> Pointer to Input vector.
                *coeff -> Pointer to coefficients.
                *temp -> Pointer to temproary data.
          Note: The algorithm reads the input data from the "in" matrix.
                First 8-point DCT will be calculated for all the 8 rows.
                This output is stored in "temp" buffer in the transposed
                form at bit reversed locations.
                Again the 8-point DCT is applied on all the 8 rows of
                "temp" buffer. Final output computed is stored in "in"
                buffer in transposed form at bit reversed locations.
                The operation of transposing the matrix and calculation of
                bit reversed are carried out while writing the data without
                any explicit code.
                Output of function is provided "in" buffer in normal order.
Registers Used:      R0, R1, R2, R3, R4, R5, R6, R7, P0, P1, P2, P3, P4, P5, A0, A1.
Other Register Used: I0, I1, I2, I3, B0, B2, B3, M0, M1, L3 registers and LC0.
Performance: (Timer version 0.6.33)
                Code Size : 240 Bytes.
                Memory Required :
                  Input Matrix       : 8 * 8 * 2 Bytes.
                  Coefficients       : 16 Bytes
                  Temporary matrix   : 8 * 8 * 2 Bytes.
                Cycle Count :
                |  Size  |  Forward DCT  |  Inverse DCT |
                |  8x8   |   284 Cycles  |  311 Cycles  |
dct_122700.zip
7.58 KB, 下载次数: 13 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-6-6 01:43:44 | 显示全部楼层
真是 太感谢了 要不然,我不知 要花躲大的功夫,写这个程序呢。
发表于 2007-8-25 20:22:49 | 显示全部楼层
我正需要呢,真是太感谢了!
发表于 2008-1-16 09:42:00 | 显示全部楼层
先了..........
GMT+8, 2025-12-18 05:41 , Processed in 0.024945 second(s), 7 queries , Gzip On, Redis On.
