查看: 3094|回复: 2
[求助] 请问RCD嵌压电路的设计公式的疑问?
发表于 2011-5-31 14:43:45 | 显示全部楼层 |阅读模式
Figure 3. MOSFET turn-off waveforms with clamping.
This implies that the power dissipated in the clamp at turn-off is
PCLAMP = (1/2) × VCLAMP × ICLAMP × ∆t × f
Where, f is the switching frequency.
However,
∆t = (LLP × IP)/(VCLAMP - VOUT/N).
The power dissipated in the clamp is through the resistor. Therefore
RCLAMP = [2 × VCLAMP × (VCLAMP - VOUT/N)]/( LLP × IP² × f)  (a)
It is important to minimize the ripple, Vripple, superimposed on VCLAMP to keep the MOSFET drain voltage close to
the clamp voltage. The minimum value for the capacitor, CCLAMP, is therefore CCLAMP = VCLAMP/ (Vripple × RCLAMP
× f
我想问公式(a)怎么理解,电阻上消耗的功率为什么那样计算的...我看的raidly也是这样写得,但是我没理解到,请大侠解释下...
参考资料:maxim AN848
发表于 2011-6-1 17:25:24 | 显示全部楼层
能不能具体到公式的某一个地方,“为什么这么写?”,你认为应该怎样写,这样大家会更容易理解/。
 楼主| 发表于 2011-6-3 10:41:15 | 显示全部楼层
回复 2# china_ic
    1/2 LP*(Ip^2)*f这个应该是在漏感上的功率吧,平衡时,这些功率应该在电阻上消耗掉。把表达式A移下就发现电阻上消耗的功率为
[Vclamp*(Vclamp-Vo/N)]/R,就是这个电阻上消耗的功率我不明白为什么是这样写得。
谢谢 china_ic!
GMT+8, 2025-12-21 08:58 , Processed in 0.042844 second(s), 7 queries , Gzip On, Redis On.
