查看: 5103|回复: 1
[资料] 基于 NUVOTON M051的BMA180 SPI驱动
发表于 2011-5-27 09:46:18 | 显示全部楼层 |阅读模式
void SPI1_init(void)
    /* Configure SPI1 related multi-function pins */
    DrvGPIO_InitFunction(E_FUNC_SPI1);
    /* Configure SPI1 as a master, 8-bit transaction */
    DrvSPI_Open(eDRVSPI_PORT1, eDRVSPI_MASTER, eDRVSPI_TYPE5, 16);
    /* Enable the automatic slave select function of SPI0 and select the slave select pin. */
    DrvSPI_EnableAutoSS(eDRVSPI_PORT1);
/* Set SPI endian MSB FIRST */
DrvSPI_SetEndian(eDRVSPI_PORT1,eDRVSPI_MSB_FIRST);
/* Set the active level of slave select. */
    DrvSPI_SetSlaveSelectActiveLevel(eDRVSPI_PORT1, eDRVSPI_ACTIVE_LOW_FALLING);
    /* SPI clock rate 2MHz */
    DrvSPI_SetClockFreq(eDRVSPI_PORT1, 5000000, 0);
printf("SPI1 initialize complete!\n");
void DrvBMA180_write(uint8_t address, uint8_t data)
//write any data byte to any single address
//adds a 0 to the MSB of the address byte (WRITE mode)
uint32_t u32Tmp;
address &= 0x7F;
u32Tmp = (address<<8)|data;
    DrvSPI_SingleWrite(eDRVSPI_PORT1, &u32Tmp);
uint8_t DrvBMA180_read(uint8_t address)
//returns the contents of any 1 byte register from any address
//sets the MSB for every address byte (READ mode)
uint32_t u32Tmp;
address |= 0x80;
u32Tmp = address << 8;
DrvSPI_SingleRead(eDRVSPI_PORT1, &u32Tmp);
return (uint8_t)u32Tmp;
// init_BMA180
// Input: range is a 3-bit value between 0x00 and 0x06 will set the range as described in the BMA180 datasheet (pg. 27)
// bw is a 4-bit value between 0x00 and 0x09.  Again described on pg. 27
// Output: -1 on error, 0 on success
uint8_t BMA180_init(void)
uint32_t temp, temp1;
uint8_t u8tmp;
// if connected correctly, ID register should be 3
temp = DrvBMA180_read(ID);
printf("ID = %x\n",temp);
if (temp != 0x03)
return -1;
temp = DrvBMA180_read(Version);
printf("Version = %x\n",temp);
// Set ee_w bit
temp = DrvBMA180_read(CTRLREG0);
printf("CTRL_RGE0 = %x\n",temp);
if ((temp&0x10)!=0x10)
temp |= 0x10;
DrvBMA180_write(CTRLREG0, temp);
// Have to set ee_w to write any other registers
// Set new data int bit
temp = DrvBMA180_read(CTRLREG3);
printf("CTRL_RGE3 = %x\n",temp);
if (temp!=0x02)
temp = 0x02;
DrvBMA180_write(CTRLREG3, temp);
// Set BW = 1200HZ 10HZ
temp = DrvBMA180_read(BWTCS);
printf("BWTCS = %x\n",temp);
if ((temp&0xf0)!=0)
temp &= 0x0f;
DrvBMA180_write(BWTCS, temp);
// Keep tcs<3:0> in BWTCS, but write new BW
// Set Range = 2g
temp = DrvBMA180_read(OLSB1);
printf("OFFSET_LSB1 = %x\n",temp);
if ((temp&RANGEMASK) != RANGE_020G)
temp &= (~RANGEMASK);
temp |= RANGE_020G;
DrvBMA180_write(OLSB1, temp); //Write new range data, keep other bits the same
// Set shadow_dis = 1
temp = DrvBMA180_read(GAIN_Y);
printf("GAIN_Y = %x\n",temp);
if ((temp&0x01) == 0)
temp |= SHADOW_DIS;
DrvBMA180_write(GAIN_Y, temp); //Write new range data, keep other bits the same
printf("BMA180 initialize complete!\n");
return 0;
// EINT0 中断响应程序 用于检测BMA180新数据
void EINT0Callback(void)
    /* Toggle LED */
int_flag = 1;
void EINT0_init(void)
    /* Configure P25 for EINT0 TEST */
    DrvGPIO_InitFunction(E_FUNC_EXTINT0);
    DrvGPIO_EnableEINT(E_EINT0_PIN, E_IO_RISING, E_MODE_EDGE, EINT0Callback);
printf("EINT0 initialize complet!\n");
发表于 2014-1-7 16:31:16 | 显示全部楼层
你好,有详细的驱动文件吗?发我一份,1126949777@qq.com , thanks.
GMT+8, 2025-12-26 09:01 , Processed in 0.019251 second(s), 7 queries , Gzip On, Redis On.
