查看: 2180|回复: 1
【ISCA论文1】Fetch-Criticality Reduction Through Control Independence
发表于 2011-5-25 13:01:59 | 显示全部楼层 |阅读模式
Fetch-Criticality Reduction Through Control Independence.pdf (994.5 KB , 下载次数: 10 )
abstract
Architectures that exploit control independence (CI)
promise to remove in-order fetch bottlenecks, like branch
mispredicts, instruction-cache misses and fetch unit stalls,
from the critical path of single-threaded execution. By ex-
posing more fetch options, however, CI architectures also
expose more performance tradeoffs. These tradeoffs make
it hard to design policies that deliver good performance.
This paper presents a criticality-based model for reason-
ing about CI architectures, and uses that model to describe
the tradeoffs between gains from control independence ver-
sus increased costs of honoring data dependences. The
model is then used to derive the design of a criticality-aware
task selection policy that strikes the right balance between
fetch-criticality and execute-criticality. Finally, the paper
validates the model by attacking branch-misprediction in-
duced fetch-criticality through the above derived spawn
policy. This leads to as high as 100% improvements in per-
formance, and in the region of 40% or more improvements
for four of the benchmarks where this is the main problem.
Criticality analysis shows that this improvement arises due
to reduced fetch-criticality.
 楼主| 发表于 2011-5-25 13:04:39 | 显示全部楼层
好贴自己顶,沙发!
求板凳、蒲团
GMT+8, 2025-12-14 05:20 , Processed in 0.021987 second(s), 6 queries , Gzip On, Redis On.
