查看: 7742|回复: 17
[求助] SIwave仿真S参数的可信度有多少
发表于 2011-4-14 14:02:32 | 显示全部楼层 |阅读模式
SIwave仿真S参数的可信度有多少
发表于 2011-4-20 17:46:28 | 显示全部楼层
According to my experience,
If Txline with a solid ground plane, the S-parameter of Txline from SIwave is closed to HFSS.
But if txline without a solid ground plane, the S-parameter of Txline from SIwave is jut closed to HFSS up to 2GHz.
发表于 2011-4-20 19:22:11 | 显示全部楼层
也不清楚呢
发表于 2011-4-28 14:30:45 | 显示全部楼层
看看再说
发表于 2011-6-21 21:09:46 | 显示全部楼层
 學習一下~~~~
发表于 2011-8-16 21:42:36 | 显示全部楼层
较早的版本试过,用4.0再试一下,呵呵
发表于 2011-8-18 18:32:16 | 显示全部楼层
Thank you.
发表于 2011-10-10 16:22:21 | 显示全部楼层
XUEXILE
发表于 2011-10-11 10:42:44 | 显示全部楼层
why not just use momentum?
发表于 2012-1-5 23:18:01 | 显示全部楼层
谢谢分享 楼主辛苦了
GMT+8, 2025-9-13 23:28 , Processed in 0.027757 second(s), 8 queries , Gzip On, Redis On.
