查看: 5551|回复: 14
[原创] PCB Layout for Switchers-NS
发表于 2011-4-8 13:00:35 | 显示全部楼层 |阅读模式
国半的资料,目录如下:1. Course Navigation
1.  1.1 Course Navigation
2.  1.2 Course Objectives
3.  1.3 Importance
2. High di/dt Loops
1.  2.1 What is the di/dt Problem?
2.  2.2 Locating di/dt Loops
3.  2.3 High di/dt Fix
4.  2.4 Low-Side FET Grounding
3. Grounding
1.  3.1 Varga's Ground Rules
2.  3.2 Dutra's Ground Rules
3.  3.3 Additional Ground Rules
4. High Current Copper Requirements
1.  4.1 Copper Trace Width Formula
2.  4.2 Copper Trace Width Examples
3.  4.3 Via Considerations
4.  4.4 Alley Ways Between Vias
5. Layer Stackup and Bypass Caps
1.  5.1 Layer Stackup
2.  5.2 High Frequency Bypass Caps
3.  5.3 Output Bypass Caps
4.  5.4 Output Capacitors Summary
6. Component Layout
1.  6.1 Component Placement Strategy 1
2.  6.2 Component Placement Strategy 2
3.  6.3 Rules of Thumb
4.  6.4 Gate Drive Layout
5.  6.5 Power FETs and Decoupling
6.  6.6 Switch Node
7.  6.7 Clean Layout - Two Sided
8.  6.8 Clean Layout - Single Sided
9.  6.9 Synchronous Buck FET Layout
10.  6.10 Control Circuit Layout - 1
11.  6.11 Control Circuit Layout - 2
12.  6.12 Thermal Considerations
7. Probing Techniques
1.  7.1 Magnetic Probes
2.  7.2 Source Terminated Probe
 楼主| 发表于 2011-4-8 13:01:52 | 显示全部楼层
回复 1# fhjltwhw
PCB Layout for Switchers.pdf
1.52 MB, 下载次数: 288 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-4-8 14:16:08 | 显示全部楼层
非常感谢
发表于 2011-4-8 15:39:58 | 显示全部楼层
谢谢楼主~
发表于 2011-4-8 22:11:05 | 显示全部楼层
谢谢楼主提供
学习
发表于 2011-4-8 22:30:53 | 显示全部楼层
Thanks for sharing.
发表于 2011-4-9 08:30:27 | 显示全部楼层
辛苦了!
发表于 2011-4-9 18:18:54 | 显示全部楼层
多謝大大分享~
发表于 2011-4-9 21:38:25 | 显示全部楼层
顶楼主,主要是看见楼主把内容目录都贴出来了,赞一下
 楼主| 发表于 2011-4-12 12:39:44 | 显示全部楼层
回复 11# bake_ql
   呵呵,免得大家资料下重复了。
GMT+8, 2025-9-15 05:39 , Processed in 0.021883 second(s), 6 queries , Gzip On, Redis On.
