楼主: superpig2b
[资料] QuestaSim/Modelsim 10.0a Crack
发表于 2011-6-13 14:10:21 | 显示全部楼层
非常感谢楼主!ddddd
发表于 2011-6-13 14:10:52 | 显示全部楼层
非常感谢楼主!dddddfdssdfds
发表于 2011-6-13 15:33:50 | 显示全部楼层
多谢楼主!!!
发表于 2011-6-18 12:53:38 | 显示全部楼层
有哪位大虾知道,为什么ISE调用Modelsim10.0a的时候老是报错的呢?
显示以下信息:
Creating automatic do files...
* udo file already exist (TB0617.udo). It will not be re-generated.
* creating main do file (TB0617.fdo) for Behavioral Simulation...
    > executing 'D:/Modelsim/modeltech_10.0b/win32/vsim.exe -version' to get the mti_se version...
    > mti_se version is 10.0b
* determining pre-compiled simulation library path information...
   > using mapping file from project dir (E:/workshop/workshop_xilinx/Xilinx Study Base/ISEpractice_new/modelsim.ini)...
   > extracting library mapping information from 'E:/workshop/workshop_xilinx/Xilinx Study Base/ISEpractice_new/modelsim.ini'...
     > Compilation info: secureip
       > secureip (=>"D:/Modelsim/modeltech_10.0b/simlib_xilinx/secureip")
     > Compilation info: simprims_ver
       > simprims_ver (=>"D:/Modelsim/modeltech_10.0b/simlib_xilinx/simprims_ver")
     > Compilation info: unisims_ver
       > unisims_ver (=>"D:/Modelsim/modeltech_10.0b/simlib_xilinx/unisims_ver")
     > Compilation info: unimacro_ver
       > unimacro_ver (=>"D:/Modelsim/modeltech_10.0b/simlib_xilinx/unimacro_ver")
     > Compilation info: xilinxcorelib_ver
       > xilinxcorelib_ver (=>"D:/Modelsim/modeltech_10.0b/simlib_xilinx/xilinxcorelib_ver")
       > unisims_ver (ERROR: Library path "./unisims_ver" does not exist)
ERROR: The library path specified in the 'modelsim.ini' file for mapping the 'unisims_ver'
       library does not exist. Please fix the ini file or recompile the simulation libraries.
INFO: Simulation process aborted!
我重新编译了仿真库 'unisims_ver',结果还是一样。而且,库的编译不能再用ISE自带的工具cmplxlib了
发表于 2011-6-18 12:56:24 | 显示全部楼层
补充一下,上面用版本是ISE12.4
发表于 2011-6-18 20:31:46 | 显示全部楼层
thanks for sharing...
发表于 2011-6-19 00:20:13 | 显示全部楼层
回复 1# superpig2b
    sdfsdfafads
发表于 2011-6-19 00:21:24 | 显示全部楼层
adfasfsafsdf
发表于 2011-6-19 00:22:41 | 显示全部楼层
sdfsadfsadfsdafasdf
发表于 2011-6-19 00:23:19 | 显示全部楼层
sdfasdfasfasf
GMT+8, 2025-11-1 03:14 , Processed in 0.017971 second(s), 5 queries , Gzip On, Redis On.
